Mass-Flo EFI
795.0
76
Anyone familiar with Mass-Flo Fuel Injection Systems? It's an aftermarket EFI system that uses mostly Ford electronics, A9L, TFI, MAP, TPS, IAC 02 sensors, ACT, VSS, injectors, etc. It does us a 85mm GM style maf, and custom 1000cfm throttle body. I was very impressed with everything I've read so far. Just want some input from someone who's had some experience with it or knows someone who has one. Thanks.
I found some info here...
http://www.mass-floefi.com/mass-flo.html
'Disguising' EFI under a carb style filter is kinda trick, but I doubt the product is anywhere near as good (functionally speaking) as they say it is.
The kit you would purchase would use an A9L - which is (arguably) our best factory Ford computer. The only thing that is not from a stock EFI Mustang is the GM MAF. While the GM MAF may be more accurate, I don't see this conversion being worth the $3,000 price tag. :nono:
They don't retune the computer, so what exactly are you purchasing?:shrug:
Maybe I just missed something in the plethora of sales gimmicks. :rolleyes: Some one there did take their Marketing classes very seriously. :p
Any naturally aspirated engine, regardless of brand, size, combination of parts, etc., requires a given air/fuel ratio, at a given load. These ratios do not change from engine to engine, until you get into forced induction applications.
Not entirely true. There are some engines that will require more fuel due to their design. Just like there are engines that can (and prefer to) run much more ignition timing than others.
Get improved power and torque as well as improved fuel economy, performance and reliability.
Be careful anytime you hear such statements. It is VERY rare when all of these characteristics can be improved with a single change. I highly doubt they can back up this claim...
Other products that make similar claims...
The Turbonator :nonono:
Slick 50 :nonono:
Any 4 point spark plug :nonono:
If you plan to make LARGE gains in horsepower, and you need to change your injector size, just return the air meter, and we will recalibrate it for you, rather than retuning, reprogramming, and more trips to the dyno.
Ask any Professional Tuner or even a self tuner (using tweecer, pms, moates, etc.), and they will all agree that 'Calibrating' the MAF output based on injector sizing is a joke at best.
It can work very well, or it can turn out horribly, due simply to production tolerances.
Without putting a car on a dyno, or performing some datalogging, there is no way of knowing what changes need to be made. If this company really does make changes as they describe, they are just guessing, the same way C&L and PMAS do. C&L and PMAS don't cost 3 grand. :nono:
There's one other thing we should mention... Speed density relies heavily on the signal from the MAP (manifold air pressure) sensor to determine how much fuel to add. This sensor measures the engine's vacuum at the manifold. So what happens when your camshaft produces poor vacuum? You guessed it... Horrible drivability is the result. Mass-Flo does not use a MAP sensor. You can use any camshaft you want with our system.
They don't use a MAP sensor because the A9L does not use a MAP, but does use a BAP.
I don't see how they can say this is a feature they created. Ford developed the A9L, and how it uses its various sensors.
Also, there are limits on what cams you can run with reliability in an A9L, especially if the tune isn't being changed for the cam characteristics.
The major change that needs to be made is the Fuel Injector Timing. If a high overlap cam has been installed, then firing the injector at the factory A9L crank angle will dump fuel directly out the exhaust .
This is why the injector firing timing must be modified, as the fuel being dumped directly into the exhaust will confuse the O2 sensor about what the combustion mixture really is.
AFR cannont be controlled accurately in this situation, which means a loss of power, torque, economy, and reliability.
:mad:
[FONT=Arial, Helvetica, sans-serif]
[FONT=Arial, Helvetica, sans-serif]We frequently get calls from people who say that they already have mass air management in their production vehicle, and when they made changes to their engine, they needed to get a chip burned to make it run correctly. Many will say that even the chip did not make it right. They are correct...​
[FONT=Arial, Helvetica, sans-serif]The fact is, there is only one management system on the planet that will allow us to do what we do... OURS!
[/FONT]
[/FONT]
[/FONT]They never say what their system does that is different than the factory A9L, so I am highly doubtful that this is entirely true.
:rolleyes:
I should admit that I have made all of my conclusions on this product in about 10 minutes. But after reading this page, I wouldn't recommend this procuct to anyone, even if I didn't really like the guy.
If someone disagrees with me, please say so. I would love to hear some other points of view on this setup.
jason
I've looked over that website a number of times researching for my '68 and I think you're overlooking a few things.
For starters, they're marketing towards guys with carburated musclecars. Those guys will definitely see an increase in economy as well as performance.
The biggest thing you're overlooking is that they offer a conversion kit for customers that already have a fuel injected Ford. You get the manifold, fuel rails, "4-barrel" throttle body, and MAF meter, and you reuse all the parts that you car is already equipped with: TFI distributor, computer, wiring harness etc. That kit runs around $1600.
The Ford 302/351w system does utilize a BAP sensor, take a look:
http://www.fordmuscle.com/archives/2006/02/EFIConversion/index.php
the system components pictured on the Mass Flo page is for the BB Chevy. Not sure why the Chevy system doesn't have one in the picture, though.
While I think they exagerate a little about not needing ANY tuning in NA applications, compared to most of the GM-based and aftermarket-based speed-Density systems, I think an EECIV MAF system is a LITTLE more adaptable....
Plus they do offer tuning, you just have wade through some text to find that part. It's kind of a moot point if you keep you factory computer (along w/ most of the sensors that are already on your car) and use the conversion kit I mentioned above, you can get it tuned by whoever you want.
The real advantages here for an EFI'ed 5.0 owner would be a reduction in weight, upgrading to the Victor Jr. intake manifold, upgrading the fuel rails, possibly upgrading the throttle-body (depending on what you've got now), and cleaning up the engine bay.
Thanks for your input, both of you bring up some good points. I'm doing an EFI conversion on an older vehicle using a 91 mustang 5.0. I have most of what I need already, sensors, A9P, stock cam, etc. I'm not too fond of the Ford EFI intakes and they also pose a few problems with the swap. The Victor Jr would look much better and solve most of my swap issues. I'm also concerned with how much torque / throttle response I would be sacrificing using the Victor Jr, and 1000cfm throttle body vs the 5.0 HO intake and 65mm throttle body. The only mods I'm planning to use are ported E7's and 1 5/8 FRPP shortys. I'm also wondering how well the A9L works with the LS1 maf. I've heard all kinds of horror stories when people use some aftermarket or non ford mafs. I've only been able to find "positive" info on it from the website and a few magazine articles. It would be cool to talk with someone who has one to see if the've had any issues with it.
Check out the first page of that link to Ford Muscle. The meter uses a kind of electronic translator that alters the signal to work w/ the Ford computer. Obviously they are addressing it, but I haven't heard from anyone who has used it w/ a stock computer, though. Over in the Classic forums a guy named 66HertzClone has posted a bunch about his Mass Flo experience, he could definitely tell you about streetability w/ that Victor Jr..
Just out of curiosity, what kind of older vehicle are you working on?
Thanks, Joncash. I'll do a search in the classic forums and send a pm to 66hertzclone. It's going in a 79 F series pickup. It's been my daily driver for the past 20+ years. Just trying to update things a little.
Interesting, it makes sense that they are marketing to carb owners...
Unless you really like the 'cool' factor of the intake syling...
$1600 is still WAY too much.
A saturday afternoon in a junk yard would yield all the parts you need to switch to EFI, probably for less than $500.
Again, the 'cool' factor may make it worth the cost. That is a decision I can't make for you.
Yes Ford systems either use a MAP or a BAP. SD cars used a MAP, while MAF cars used a BAP.
I would argue that the EEC-IV system is VERY adaptable. I ran my 408w with a stock computer, no tune, for several months. It ran better with the tune, but it wasn't bad on the stock computer.
Personally, I don't think running a short runner intake is a good way to cut weight.
The loss of low end torque for the 302 is too great to be offset by the minimal weight loss.
My entire point is that these guys are selling a factory Ford EEC-IV A9L EFI system, with a conversion for a GM MAF.
This setup is not that special. I doubt most drivers could tell the difference between how their car runs with the Ford resistor MAF vs with the GM vortex MAF.
For the cost of the kit, you could get a h/c/i kit and a computer/harness/sensors from ebay or a yard.
For the $1600 kit you could get a computer/harness/sensors and a tweecer RT. Probably have cash left over if the build was modest and smart.
The only thing I see that is special about this setup is the GM MAF conversion. However, I don't think that is worth what they are charging.
From a functionality point of view, there are better things to spend this much money on.
I seem to be in the minority so I will probably shut up now. :p
Good luck, and let us know what you think of this kit if you go that route. Or why you didn't use this kit if you find another option.
jason
I agree with Vristang.
If you can get the A9l, put together a manifold of your choice. Have the manifold drilled for injector bungs. Buy a Tweecer, raid the junkyard for the rest. You can come out way, way, way ahead.
But, you'll have to learn all about fuel injection. You'll need hours and hours of research.
Mass-floEfi is the magic Mustang kit price, 3000$.
Like many other 3000$ options, there is minimal screwing around. It comes in a box, you install it, hook it up, and it goes.
You can build a rear end much cheaper than Currie will sell it to you, 3000$.
It all comes down to Economics.
Opportunity cost.
What will it cost you to spend the time doing it yourself rather than outright paying for it.
If Bill Gates wanted a custom EFI system, would he spend his time researching how to do it, or would it be more cost effective for him to just buy the
Mass-floEfi kit. He'd buy the kit. Those hours are worth much more to him utilized in his field of expertise.
I, on the other hand, don't make s**t. So, it's worth it to me to research and screw around until I figure it out. Plus, I often need a break from the work I regularily do.
I graduate soon, won't make a hell of a lot of money at first. Later I'll go to graduate school, probably will make a lot more money. At that point, maybe I'll just buy the Magic number kits.
For now, I'd rather just do my homework.
Ok, I've beat this to death.
Hey, magic number 69 post, sweet... My wife is in trouble tonight...
