alright-heres the gist-
car is a 99 gt, bought it salvage due to the fact that it had an interior fire-everything iside was roasted, engine/etc was untouched
parts came from 2 different cars-
1. 1999 gt-from this car i used all door locks, pcm, dashboard, cluster, ignition, column, and key
2. 2002 v6-from this car i used the complete interior wiring harness, interior, and misc. other parts
PROBLEMS:
nothing works properly-the car will crank, but the anti theft light blinks-however, it did start once, only to die after 10 seconds. occasionally if you cycle the key the light will cease to come on. ALSO the theft light will not come on when the headlights are on? but still wont start. NEXT the gauges dont work at all-occasionally the needles will move, but go right back down. The windows dont work, nor do the door locks-the chime for open door works, as do the power mirrors. ODD-now heres something that makes me think i missed a ground wire-when you turn the heater or hit the power seat switch, etc on (none of which work) the radio will get power and come on, gauge illumination, as well as some other small things. The headlights work (both hi, low, and foglights), but the front running lights stay on-4 ways dont work, nor do the blinkers, and when the 4 ways are put on the car will make a horrible buzzing sound-
my ideas-gem module, pats system (99 gt parts sat for 2 years in a garage) as the anti theft light does blink-but i really doubt that is causing all the rest of the interior power issues. More than likely i forgot a ground somewhere in the dashboard-DOES ANYONE KNOW IF THERE ARE ANY GROUDS THAT TIE THE DASH HARNESS TO THE CHASSIS? i didnt hook up any grounds besides the one in the pcm harness, which is from the 99gt parts car
PLEASE HELP ME! i want this car running SOON
PROBLEMS:
