Master Cylinder question???
  • Thread starter Thread starter Stangboy67
  • Start date Start date Oct 18, 2006
Stangboy67
59
Lynnwood, WA
Oct 18, 2006
  • Oct 18, 2006
I'm setting up a late model power booster/MC install in my '67 and I have a question or two. The booster/mc is out of a '90 5.0. What is the hole on the bottom-center of the master cylinder for? It is right under the brake line port closest to the booster, "pointing" strait down, threaded and looks as though a brake line would screw in it? It is also wet with what appears to be brake fluid.
I wasn't the one that removed it from the car. Does a sensor screw in here that I can just plug? Also, just to make sure, which port serves which set of brakes? On the '67, the front port is for the rear brakes. Is this the same on this '90 version?
Thanks for your help!
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Oct 18, 2006
  • Oct 18, 2006
I'm not sure... let me look for some pictures to see if I can help you out.
Edit - it's the best I can do at the moment... Let me dig some more for a better shot
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Oct 18, 2006
  • Oct 18, 2006
I can't find anymore pictures that I have stored online. If no one else comes along with information, I'll make a phone call and find out what is attached to that port on the bottom.
Stangboy67
59
Lynnwood, WA
Oct 18, 2006
  • Oct 18, 2006
srothfuss, thanks for the help. Unfortunately I can't tell from that photo. I suppose I could pop the hood at a used car lot
thehueypilot
1,084
Medina,Tennessee
Oct 18, 2006
  • Oct 18, 2006
Try this link:http://www.svo73mm.cjb.net/
Mustang5L5
Mod Dude
Feb 18, 2001
43,382
18,125
224
Massachusetts
Oct 18, 2006
  • Oct 18, 2006
The Fox Mustang has a VERY odd brake setup.
The MC has 3 lines coming from it.
2 of those 3 lines go to the distribution block just underneath. One line then feads both rear drums, the other line feeds the passenger front brake only.
the 3rd line off the MC goes DIRECT to the driver's front brake.
It's a terrible setup that results in the front brakes seeing unequal pressure and causing the driver's wheel to lock up before the passenger wheel.
I would try to use a 2-port MC before using the 87-93 3-port MC setup.
trbkrb
1,976
Houston, TX
Oct 18, 2006
  • Oct 18, 2006
If you want to use that MC, you can get a plug for it. A friend that has installed line locks on several Fox cars plumbs the two front lines together after the distribution block, and just blocks off the 3rd port. It looks like he uses a 10M x1.0 set screw.
Stangboy67
59
Lynnwood, WA
Oct 18, 2006
  • Oct 18, 2006
Thanks all. That clears it all up rather nicely.
trbkrb, did plugging the one port work well? I might just go out and get a 2-port MC and be done with it. So, from what I understand, the smaller the bore the lighter the pedal effort all else being equal? Will a disk/disk mc ('94-'98 V6?) work with a disk/drum setup with a proportion valve?
Thanks again
trbkrb
1,976
Houston, TX
Oct 19, 2006
  • Oct 19, 2006
I know several guys have used his "plans" with their installs and I haven't heard about any problems. He says the screws are rather hard to find, but not expensive. He bought some in bulk a while back and was selling them to friends for their installs.
As for the 94-98 MC, yes it will work. I swapped my MC first to a new 94-95 MC, since my old MC went out several months before I swapped to 5 lugs and SN95 front, Mark VII rear brakes. It worked OK, but the pedal was a bit harder than with the stock Fox MC. And yes, the larger the MC bore, the harder the pedal effort is. A 94-95 Cobra unit would give you a softer pedal than the V6-GT unit.
Stangboy67
59
Lynnwood, WA
Oct 20, 2006
#10
  • Oct 20, 2006
  • #10
Thanks!
I appreciate the help!
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
68 manual disc/drum master cylinder
  • Butchd88
  • May 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 27, 2026
Butchd88
R
Fox Hydroboost conversion/proportional valve
  • RubyRedNotch
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2026
RubyRedNotch
R
A
SN95 Hydroboost in a Fox | Brake lines
  • arc_jpiv
  • Sep 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 14, 2026
2000xp8
Brakes Front brakes sticking - 1988 5.0
  • 302Blue
  • Oct 18, 2024
Fox 5.0 Mustang Tech Oct 19, 2024
ustacould
