Master Cylinder questions
bit
1,975
Anderson, SC
I am currently putting 95 GT brakes on my 91. Do I have to use the 95 GT master cylinder? What is the advantage? Can I use a 95 GT proportioning valve or do I need an adjustable valve? If I have to use a 95 GT master cylinder what fittings do I need for the 3 to 2 conversion? I am trying to do this on the cheap so I really don't want to by the MM kit.
thanks
Brent
The MM Kit is probably your best bet as far as being neat and saving yourself time and their 3-2 kit is not very expensive anyways. You also will need to gut your stock prop valve and put the FMS Brass Plug in and then add an adjustable prop valve.
Do I even need the 95 GT master cylinder? I think I have seen it done with out it. Like I said I am trying to do this cheap so if I can buy $10 in fittings instead of a $35 kit that would be great.
