Maximum Motorsports NEW "True" CC Plates for 05-07 Mustangs
StangSuspension
58
StangSuspension.com is proud to carry the new Maximum Motorsports Caster / Camber plates for 05-07 Mustangs.
Part # MM5CC-1
The new MM plates are the first "true" Caster & Camber adjustement plate for the new S197 Mustang. By true, we mean they can adjust both caster and camber independently. Most other plates on the market only adjust camber.
We have these plates in stock and ready to ship to our customers!
Here are some of the features of this new Maximum Motorsports product:
  • Bolts on! No drilling or cutting required.
  • 1.6-degree continuous range of camber adjustment provides alignment correction on lowered cars, and is adjustable without affecting caster.
  • 0.7-degree continuous range of caster adjustment provides correction for OEM production tolerances.
  • Caster and camber are easily adjusted at the top of the strut tower.
  • The range of suspension travel can be shifted, allowing for additional bump travel on lowered cars.
  • Teflon® lined spherical bearing eliminates deflection and precisely locates the strut shaft, while still allowing the required articulation.
  • High-tech composite thrust bearing transfers the spring load into the strut tower.
  • All parts are either plated or powder coated for great looks and long lasting protection.
  • Lifetime manufacturer warranty against spherical bearing or plate failure.
Click here to check out the product on our site...
