  • 1994 - 1995 Specific Tech
Maximum rear wheel width?
  • Thread starter Thread starter jasonlee0704
  • Start date Start date Aug 24, 2004
J
jasonlee0704
219
Kansas City, MO
Aug 24, 2004
  • Aug 24, 2004
What's the formula to calculate the maximum tire width allowed by a certain wheel width? Does anyone know?
For example, a lot of people quote 275 mm as the maximum width of a tire for a 9" wheel. But nobody bats an eye at the 94-95 Cobras, which mounted a 255 mm tire on an 8" wheel, which is actually more extreme.
275 mm tire :: 9" (228.6 mm) wheel = 83.1% wheel/tire ratio, 46.4 mm difference
255 mm tire :: 8" (203.2 mm) wheel = 79.7% wheel/tire ratio, 51.8 mm difference
And then there's the 93-95 Lightnings, which mounted a 275 mm tire on an 8" wheel, or a 73.9% ratio and a whopping 71.8 mm difference.
I did some searching through the forums and even Google, but I didn't find any convincing answers anywhere. I was trying to figure out if I could put 295 mm tires on my new rear wheels for my 95, which are 18x9.5" with 6.12" backspacing.
They have 265 mm tires on there right now, which amounts to a 91.1% ratio and a 23.7 mm difference. Slapping on 295s would change that to a 81.8% ratio and a 53.7 mm difference.
For reference, new Lightnings mount P295s on a 9.5" wide tire - but I didn't know for sure if that applied to a Mustang. The largest wheel/tire difference I could find in a Mustang were the 1993 Cobras, which mounted 245s on a 7.5" wheel = 77.8% ratio, 54.5 mm difference, but that's also a 17" wheel, and I don't know if the increased sidewall height allows for a larger difference or not.
Any insight would be appreciated.
blksn955.o
3,263
st.louis mo 314
Aug 24, 2004
  • Aug 24, 2004
A larger sidewall will make it easier to mount a wider tire, as with the "L"s they run a taller tire (more sidewall).
baglock1
The Bartender
6,612
Space Coast, FL
Aug 24, 2004
  • Aug 24, 2004
There really isn't a formulas as it's dependant not only on section width, but aspect ratio (sidewall height), and even sidewall construction. The best thing to do, is look up what the min/max wheel size is for the specific tires you want to run.
J
jasonlee0704
219
Kansas City, MO
Aug 24, 2004
  • Aug 24, 2004
Thanks, guys, for the help.
swingline
1,252
TCB - Taking Care of Business
Aug 24, 2004
  • Aug 24, 2004
A 295 tire on a 9.5" wheel will be fine.
95Vert
1,785
North Mexico (deep south Texas)
Aug 24, 2004
  • Aug 24, 2004
sorry for the short hijacking but will 285-17 fit on my 99 cobra wheels, i have no idea how wide they are. currently, i have 255-45-17. i want to go as wide as possible without switching wheels
go-stang5.0
2,244
Glenview,Il
Aug 24, 2004
  • Aug 24, 2004
95 vert, are those 17x9's or 8's? If there 8's then no I wouldent recommend it. If there 9" wide then a 285 will be fine. Some guys run 275's on a 8" wheel but if you corner I wouldent recommend it, 265's at the most on that one.
95Vert
1,785
Aug 24, 2004
  • Aug 24, 2004
how can i found out if it's 17x8 or 17x9
baglock1
The Bartender
6,612
Space Coast, FL
Aug 24, 2004
  • Aug 24, 2004
If they're regular 99 Cobra wheels, they're 17x8.
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
M
Need Wheel Measurement Help Please
  • MintyFresh
  • Nov 15, 2022
1965 - 1973 Classic Mustangs -General/Talk- Nov 16, 2022
manicmechanic007
K
SOLD 1988 Ford Mustang GT, lots of upgrades, Maximum Motorsports Suspension PRICE DROP $6800
  • kuhl0040
  • Aug 18, 2021
4K
Fox Body Mustangs For Sale (1979-93) Sep 20, 2021
Drivetrain 33 spline SN axle with ABS and parking brake build
  • revhead347
  • May 12, 2020
3K
1994 - 1995 Specific Tech May 12, 2020
revhead347
