McLeod Twin Disc Users
last I checked the flywheel alone from Mcloed was like 500+ bucks or something. Have to remember it's not a normal flywheel, it has spacer recesses and dog bones on it for the twin disc and everything is set up and shimmed as a complete unit. I believe mine has removeable weights so the balance could be changed. Remember when you go to a twin disc you have to cut the bearing retainer snout back 7/16" to allow the clearance for the second disc. Call Red or his tech side kick who will answer calls, I can't remember his name right now, but either will tell you all you need to know. 714-630-3668
