My Mustang has a warmed over 302 and AC and currently everything works fine, except for when its 100 or so degrees outside. Then it starts to run a bit too warm when sitting at stop lights. Its about 205 degrees. Thats with the AC off. When the AC is on, it doesn't really seem to make a significant difference, maybe 210. The rest of the time even if its 90 or so outside, it runs at about 190 give or take.
I have a not so normal application and can not seem to find anything that will fit in the space I have to work with.
My 65 has a Fluidyne direct fit 5.0 swap radiator that is about 1 inch thicker than the stock radiator. I also have the thicker composite shroud. I'm currently running a reverse rotation 16 inch Flex A Lite flex fan. I'm not real big on this setup although it does seem to work pretty well. I would like to find a better fan setup.
I am looking for a reverse rotation clutch fan that will fit in the tight space between my water pump and radiator which is about 3 inches. Is this possible?
I have looked at electric fans and can not find any that move enough air that will fit. So, I'm looking at other options.
I guess if a clutch fan wont work, I may have to go back to a fixed blade fan like this, although I don't want to do that.
http://www.summitracing.com/parts/DER-17417/
I was wanting to use one of these fans. I was leaning towards the Derale because its all steel. The Flex A Lite has aluminum blades.
http://www.summitracing.com/parts/DER-17917/
http://www.summitracing.com/parts/FLX-5917/
I need a shorter than stock fan clutch. Does anyone know of a place that you can order shorter ones? Summit and Jegs don't list many options.
