Megasquirt MSPNP2/94 Mustang 302
Meo68
12
Im having issues trying to get my car to start and idle so I can begin to tune. The car will start but dies after a short while.Here is what I have tried so far
1. All my sensors have been recalibrated.
2. I locked timing and confirmed I was at 20 degrees before TDC.
3. I have messed with the settings in the startup and idle section but no luck.
4. I have calibrated the WB but i can't get any readings out of it. Removed jumper 6 and tried it in place as default. no diffrence.
The engine is a stock 302 with 19lbs injectors and a xe266hr compcam.The WB is a aem 30-0310 Still new to the tuning stuff so all help will be appreciated.
  • Sponsors(?)
Meo68
12
Hi
Having issues getting any reading off of my aem 30-031. Have connected white wire to pin 21 & brown wire to pin 22. Messed around with J6 to no awail. Anyone got any clue to what else might be the issue? Or are these aem WB just tricky/picky to connect.
Meo68
12
Part number link: https://www.aemelectronics.com/prod.../x-series-inline-wideband-uego-afr-controller
As for the installation part: the white is connected to pin 21 on options port, and the brown is connected to port 22. Rest of connections is standard, red to switched positive and black to ground shared with computer. The green light on controller box is green and everything should be a okay. The main harness is a painless 60510.
Meo68
12
Yes, made custom linear WB, 0,5 V - 8,50 and 4,5V 18,00 as per instructions in the manual. And made some adjustment to ego controle
Meo68
12
Hi, doublechecked J6 today and it was removed.
But i found the culprit of the problem. When connecting pin 21 & 22 they probably came loose from me thugging and pulling on them.
Adding photos of connector and how they were seated before and after for others to reference to not make same mistake as me :)
So finally made the car run for a bit and made a data log. Didnt have the time to get it all warmed up today, but hopefuly enogh data for someone to give me some pointers on what to correct.
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
9,602
5,796
204
31
Hillsborough county
1. get the car up to temperature.
2. tune the main VE table for idle and around idle set it all to the same value to achieve a uniform PW and an AFR of 14.3
3. lock the timing and the idle valve using testmodes. figure out the values that the idle valve functions between use this to help setup the closed loop idle.
4. watch my videos
5. watch them again.
do these first and lets see how far you get.
Reactions: DemonGT
Meo68
12
Anyone got the correct Injector dead-time settings for 19 lbs injectors? I have found 2 diffrent values 420/120 & what i have now 572/155 and not sure what to use.
Meo68
12
This is what i have found so far, any thoughts?
Injector Flow CC/min Flow LB/Hr Ohm 10v 11v 12v 13v 14v 15v
Ford mustang (84-95) 200 19 15 0.86 0.67 0.56 0.43 0.34 0.2
Ford Mustang Cobra� 252 24 15 0.91 0.73 0.59 0.46 0.36 0.25
Thread starter Similar threads Forum Replies Date
C Megasquirt MSPNP2/95 Mustang 347 Digital Self-tuning Forum 0
94Vortechcobra Connecting Wideband to Megasquirt PNP2 Digital Self-tuning Forum 2
J Learning so much but still have some questions with megasquirt Digital Self-tuning Forum 1
G megasquirt trouble Digital Self-tuning Forum 2
B Megasquirt pnp2 maf wiring Digital Self-tuning Forum 3
Old Catman EFI and megasquirt questions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
GodStang Megasquirt MS3Pro Injector Swap Digital Self-tuning Forum 3
B Megasquirt wideband problem Digital Self-tuning Forum 12
M 93 foxbody 347 stroker megasquirt 2 pnp initial timing set up?? advice Digital Self-tuning Forum 6
C 1995 Mustang GT Megasquirt Timing and ignition settings question Digital Self-tuning Forum 36
C Megasquirt & Dirty Dirty Racing 1994 - 1995 Specific Tech 8
M Need help tuning megasquirt with kenne bell supercharger Digital Self-tuning Forum 9
atey950 89 5.0, Trick flow stage 1 h/c/i, Megasquirt pnp novice needs help Digital Self-tuning Forum 4
J Any benefits to running mass air with megasquirt? Digital Self-tuning Forum 3
W Autometer wideband with megasquirt pnp 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
S Megasquirt PNP2 460SBF startup/idle issues Digital Self-tuning Forum 9
beyondEOD Fuel Pressure Sensor with Megasquirt Digital Self-tuning Forum 15
S Using maf with megasquirt pnp Digital Self-tuning Forum 7
beyondEOD 94-95 Mustang GT Auto Dual Microsquirt ECUs Digital Self-tuning Forum 14
R Megasquirt installment 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
DemonGT Holley Terminator X vs Megasquirt pnp2 Digital Self-tuning Forum 12
R ECU Tuning Help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
S Wide band reading vs megasquirt Digital Self-tuning Forum 6
HemiChall Ego Control setting for megasquirt with AEM wideband Digital Self-tuning Forum 14
S Megasquirt pnp idle issues Digital Self-tuning Forum 19
CHILL347 MegaSquirt PNP2 Outputs Digital Self-tuning Forum 5
L Need help with Megasquirt 331 HCI Digital Self-tuning Forum 12
9 MS2 Cold Start Issues Digital Self-tuning Forum 6
droopie85gt Megasquirt questions Digital Self-tuning Forum 35
stanglx2002 Service Provided Megasquirt Digital Dash Services - Tuning, Welding, Mechanic, Body Work... 0
a91what Service Provided Megasquirt ECU support and Tuning Services - Tuning, Welding, Mechanic, Body Work... 5
M New guy here! turbo megasquirt The Welcome Wagon 1
Wilky-Medusa 2.0 Medusa Megasquirt.... help lol Digital Self-tuning Forum 118
Mazzzaaa 95 Mustang MegaSquirt tune or stock computer Chip tune? Digital Self-tuning Forum 19
B early bronco megasquirt pnp2 amortization thread Digital Self-tuning Forum 20
9 MegaSquirt 2 Digital Self-tuning Forum 26
stanglx2002 Megasquirt Digital Dash Digital Self-tuning Forum 45
Blucifer99 First start up using megasquirt.. 1992 5.0. Digital Self-tuning Forum 500
a91what Megasquirt tuning videos// what would you like to see explained in the software? Digital Self-tuning Forum 21
Blucifer99 92lx. Whats the difference between microsquirt and megasquirt for fox mustangs Digital Self-tuning Forum 10
Q For Sale Fox Vortech v-2, and megasquirt pnp ecm. Engine and Power Adder 1
S 1991 stock 5.0 on3 turbo megasquirt tuning. Digital Self-tuning Forum 31
vristang Talk Me Into Using Megasquirt? Digital Self-tuning Forum 7
stanglx2002 Progress Thread '88 GT Hell Horse - All over the place 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 448
a91what Megasquirt/tuner Studio Tech Thread Digital Self-tuning Forum 16
AUBURN1111 Digital Tuning Megasquirt 2 Pnp Basic Tune, 1st Time Install Fox 5.0 Mustang Tech 5
AUBURN1111 Megasquirt Pnp Install Fox 5.0 Mustang Tech 1
SlowFiveOh Megasquirt Tuning Questions Fox 5.0 Mustang Tech 5
2 Expired Megasquirt Ms2 Pnp Engine and Power Adder 1
hoopty5.0 Steve's Megasquirt/tunerstudio Help Thread Digital Self-tuning Forum 1303
