well my friend's oil pump seized up on him and we pulled the pan and he reached around in thereand pulled out like 5 good size pieces of metal. we took out the pump and took off the plate to find something that resembles a pin or something. as thick as a paper clip, but not close to being the size of a paper clip. the oil wasn't "metallic" so there weren't any small shavings in it. there's no way this came in through the top end. the pieces of metal almost look like a washer cut in half. they look too small to be a part of a piston ring. the distributor shaft did wiggle around. could it be a part of the distributor that fell down in there? that's the only way that i could see big chunks of metal getting into the pan.
any thoughts are welcome
thanks,
chris
thanks,
chris
