Meth injection vs. Intercooler
Thanks for posting the link to their site! I hadn't checked it out in a long time!
They have a controller that will cut the timing and turn on a red light if the fluid is low. They also have a float swith that will turn on a light if its low, which would be way cheaper and do the trick for me. $25 for 4gal of "Boost juice" seems pretty cheap!! I would run that especially since I don't daily drive it. So it took you a 5 months to go through 4 gal?
Also they say that every kit now comes with a "new and improved pump" for no extra charge!!
Yeah, I bought 4 gallons of boost juice when I put the kit on it in early July, and I was pretty much out by the time I put the car away right after Thanksgiving.
I am pretty sure I am using the medium nozzle that came with the kit, so it would go quicker if you needed to use a larger nozzle.
I have mine set up to start spraying at 2 PSI of boost, and then the pump will be full on at about 10 PSI.
As much as I would like to turn up the boost, I figure I need to stay where I am at on the stock bottom end. I am making about 10 lbs of boost off of the Vortech kit with an AFM power pipe.
I am pretty sure the pulley size is a 3.33" blower, and 6.87" crank pulley.
The power gains were all from the meth kit and adding only a couple degrees to my base timing. I know that I could have gotten some more horse power out of it, but I'll wait till I get a stronger block for that. I don't want to push my luck too far. :D
Well I have a Sportsman block with girdle, so I am not so worried about the block. I get a lil bit of blow-by though, so I think it'll be the oil rings that go first. :owned:
I also have 9.5:1 compression so I am trying to figure out how to run 12-14psi and methanol. Should be good for 500+rwhp and hopefully safe.
I was thinking about using a 7 or 7.5" crank pulley and leave the blower alone @ 3.33", that way I dont risk belt slippage. :nice:
i just scored a snow kit off corral for 310 shipped. so i'll be running this before summer hits. those intercooler pics are crazy. first time i've ever seen that much tubing in that small of an area.
