i have the harness but i cant figure out what i'm suppose to connect the 4 wires on the white connector to. there is a set of RCA's on this connector that i plugged into the output from the dvd player. any help is appreciated
i even figured out how to bypass the new style parking brake cut off. you cant just ground them anymore. it has to be an open circuit when the radio turns on and then ground once the radio turns on. all you need is a relay
you can use a relay just get a 4 wire relay. wire 85 to your remote turn on, 30 to parking brake wire, 87 and 86 to ground.
this will turn the radio on and then ground it so you can watch DVD's while driving.
Looks like a VS Pro remote in the first picHave you thought about the Scosche kit and a regulator for amp pop?
any reason my front lower door speakers arent working with this harness??
