Mexican block questions
RYC CUKR
1,437
Orlando
I have a chance to get a mexican block but I have a few questions before I make my decision.
First, the engine has just come out of the machine shop and is bored .060" over. I know that on a thinwall block casting block this is kind of a :nonono: but is it ok with a mexican block.
Also what needs to be done to convert it to run a roller cam and roller lifters. Will I need to use the link bar retrofit lifters or can stock style be retrofitted into the engine?
Thanks for any info.
i think there are only 2 ways to convert to roller lifters. The first is to buy retrofit linkbar lifters from crane they are like $400 without a cam. you can also use a reduced base diameter cam and tap the valley so you can bolt a stock spider down and use the stock dogbones.
try over on nmraracing.com.
The Mexican has thicker webbing around the mains but I don't know what the limit on the bore is. the max bore on a 302 safely is .040 over. If it is OK, there will not be anything left to bore if u ever have an issue.
RYC, I currently have a mexican block that im turning into a 331.
As far as the roller cam issue there are two ways.
A) Use the retro-fit crane kit which is somewhat expensive.
B) Use the dogbone and stock lifter. This will require you to tap the block AND use a special small circle base cam.
Either way you cut it... you will end paying around the same amount due to the cost of either the retro-fit kit OR the needed small circle base cam.
As far as .060 over. thats a tad much. The mexican block is a little stronger than the stock 5.0l. However, its NO dart block! You could and CAN get away with that bore. But if you heart is set on a mexican block you might as well wait it out till you find one untouched or just at a .030 bore.
Cool?
ps. dont forget the other issues.. such as the block having no provision for the oil dipstick... (you need a pan that has one) and etc.
I have what I call an X block. It has 3 xs in the oil valley. It supposedly has thicker cylinder walls. I was told it was bought as a ford crate engine for a 95 GT and it was .060 overbored from the factory. It ran hot in traffic last summer with a bad clutch fan and underdrives with the AC on. I fixed the fan, if that don't keep it cool i'll go back to stock pullys in the summers. Can anyone confirm the X block having thicker walls?
