- Oct 13, 2004
- 4
- 0
- 0
I just recived my MGW shifter for my 03 Gt this has been beaten to death but should I intstall the shift stops or leave them out like the instructions say??
Thanks.
Thanks.
:Word: putting them in is only added protection as long as you set them back far enough.BooWFO said:It's your call. I put mine in but set them out a lil further than I normally did on t-5's .
Wait, the T-45 has built in stops too? I thought it was only the t-3650?svttech76 said:personally I say leave them out unless you KNOW they are adjusted right. and if they are adjusted right they are not stoping anything anyways, so why have them at all.
the t-45 and t-3650 have built in shift stops and can not be overshifted. tremec themselfs issued a statement saying they do not recomend the shift stops be used. and I have personally seen several trannies with shift fork damage do to shift stops that were out to far.
so they don't help you and they can rattle loose and then end up causing you to pop out of gear. so why use them
