MIL w/ no stored codes?
  • Thread starter Thread starter iLkYsPoNy
  • Start date Start date Nov 24, 2006
iLkYsPoNy
if she's a tranny then... well I'd do her.... it..
Aug 8, 2006
60
Sandusky, Ohio ( Cedar Point - America's Rockin' R
Nov 24, 2006
  • Nov 24, 2006
Sometimes but not all the time when I get on my car in 2nd gear my check engine light will come on then go back off. It's only 2nd gear, not always WOT and never light acceleration. There aren't any stored codes. What the hell is going on????
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 24, 2006
  • Nov 24, 2006
Do you get an 11 that says everything is OK?
iLkYsPoNy
Aug 8, 2006
60
Nov 24, 2006
  • Nov 24, 2006
no... i guess i don't..... so now what?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 24, 2006
  • Nov 24, 2006
You should get two flashes which is an 11 once the jumper or code reader is in place and the key is turned on. No 11 and you have other problems.
Just in case you may have missed something, here's the proceedure to dump the codes.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
There is a test path to find & fix the cannot dump codes problem if you still cannot get the codes to dump.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
