90NotchBack said:It's has nothing to do with the alxes as long as they have the same spline alxes. It's because the mini spool wont fit in the trac lock housing. A open rear has a bigger housing so the mini spool fits right in there.
89MustangGX said:Are you sure about the bigger housing? The housings look the same to me -- I would think it's more room inside because of the open setup vs. the Trac-Lok.
raph130 said:yeah it hast to be in pieces so it can be compatible with the cclips. those 2 blocks rattle slightly and with rpm they are noisy. but id enver go back to a trac loc. i love the way it feels with the axles locked together.
raph130 said:theres a screw in the trac loc housing that goes through the crosspin and prevents it from coming out. how did it come out? he must have alot of power.
raph130 said:lol wow! better get a hardened one next time. i believe a hardened crosspin is required when you go with 4.30s for some reason.
raph130 said:i am thinking of getting a small stiff spring at autozone similar to a valve spring and install it between those 2 blocks. the cross pin will then go through the trac loc and this spring to keep it in place and will put force on the blocks and prevent the clunking noise they create.
