SOLD Supercharger adapter for small roots/carb setup
This is an adapter that will allow you to use a small B&M, Weiand supercharger on a regular intake.
It is new, I think it is for the 144 and 142 superchargers but can be adapted for others.
The measurements from (center) bolt hole to bolt hole is: 9 3/4" $75.00
10 Rib Supercharger Belt $25
New K100465HD Green Stripe Check to see if it will work for you, it was for a SBF setup using a B&M 144, I have a custom idler setup and it was never used.
Belt / Sprocket Specifications
Effective Length (in): 46.48
Effective Length (mm): 1181
Number of Ribs: 10
Outside Circumference (in): 47
Outside Circumference (mm): 1195
Top Width (in): 1.367
Top Width (mm): 35
Customer Pack: 1.0
Standard Pack: 29
Product Attributes
Section: K
Weight
Weight (Lbs.): .47
$25
Billet and Holley DP base plates $40 and $25
The billet one works great for a large cam or in a situation where you would have drilled the holes in the plates. I had it on a 306 with a small b-cam and could not get the idle down unless I used a strong spring. Ran great just had a high idle. $40
Holley 650 DP Base Plate worked fine, no cracks. I had a back fire and a blade came loose so I cleaned it up and put it back on and then drove it again for another few hundred miles, ended up going another route. $25
The reg bracket can go for $10, it is new but for some reason did not fit for me, I cannot remember, it may be for a Vac. Secondary?
BBK Hi-Volume inline Fuel Pump $75
BBK 1602 comes as you see it with the line and one mount. Worked fine when removed, had low miles. Use it to add a pump for boost.
50 GPH more info: BBK Performance 1602 - BBK Power-Plus Series Inline Fuel Pumps - Overview - SummitRacing.com $75
The Walbro works fine but I cannot verify it is a 255 like I thought, it only says: 21897-2B and A0H036 I will throw it in free or take $20 for it.
Chrome SBF water pump pulley (Mustang)
I bought this new and never used it. For reverse rotation ford setups. $20
Number of Ribs: 10
Top Width (mm): 35
Customer Pack: 1.0
Standard Pack: 29
Product Attributes
Section: K
Weight
Weight (Lbs.): .47
$25
