Misfire Question
dml1964
Oklahoma
I have a 2001 Mustang 3.8 v6. I have rebuilt the engine and for the most part it is running great. I am getting an intermittent misfire on cylinder 2 and 6. I replaced the coil pack becuase it appears to have arc lines at the bottom right under the 2/6 coil. However it didnt fix the problem it did seem to improve some though. Can the cam synchronizer not being in perfectly cause a mis fire on just those cylinders? I think I may be off slight on the cam sync. Those are now the only 2 codes I am getting, I was getting a p1309 but after moving the cam sync that has not popped the last couple days just p0302 and p0306.
Arc lines are caused when it's easier for the spark to take an alternate path than through the spark plug gap. The things that might cause this are:
  • Excessive spark plug gap
  • a break in the spark plug wires.
  • Mis-routed spark plug wires. Crossed wires or wires run to the wrong cylinders.
  • a lean misfire caused by a clogged fuel injector.
IMO the worst thing that a cam sensor issue could cause would be timing related.
