I just dropped this stock 94GT long block in my 91LX.
Stock 302, Cobra Manifold, Cheap CAI, MSD Coil, T3550, MAC Shorties, Flowmasters, A9L
Fuel pressure is 42 at idle no vaccum
Plugs are autolite 25's set gap .050
Timing 10*BTDC
Idles at 700ish, revs well, and returns to idle well, but there is a slight mis at idle.
The real problem is driving under any load (ie any uphill, no matter how steep), I get a misfire that feels like a burnt plug boot. It hesitates, car jerks slightly, definatly losing power. Part throttle on flat ground feels ok...
Going down hill, I can stomp on it, and it feels ok?!
I have gone over every vaccum line with a propane bottle, and even pulled the upper back off and replaced the gasket...again.
I have tried two different dizzy's wtih two different rotors, tfi's
I have tried the stock MAF off my 94gt
I have tried pulling the plugs, regapping, they all look clean, equal etc....
I have tried two sets of plug wires on two different caps, along with misting the wires with water at night.... no spark leaking....
I have tried my MSD HVC Blaster coil, a stock coil, and even an old can style coil off my bronco.....
I checked the TPS and its at .80 closed. I cycled it through, and couldn't see anything I would call a dead spot...
The only code I pull is 44/94 regaurding the smog pump....
Any help would be.... well super....
Timing 10*BTDC
