Engine Miss Fire?
awellman
Columbus, OH
i have a 91 GT 5.0 has a lot of mods so ill just mention them as needed. when im staying at a constant rpm, 2000-2500 mostly, itll star running rough like its going to bog out. when i try and give it gas it will hesitate. any idea why?
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
Or for a nicer scanner see www.midwayautosupply.com/Equus-Digital-Ford-Code-Reader/dp/B000EW0KHW Equus - Digital Ford Code Reader (3145It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $22-$36.
You don't need a scanner. Just a paper clip to jump the test port out.
These older OBD1 cars do NOT flash a check engine light for every code. Only about 15 or so of the 100 possible codes make the light come on.
Dumping the codes is step #1 when anyone posts a "what's wrong with my car" thread. Why guess when you can get a good starting point.
If you suspect a missfire, run a cylinder balance test to narrow down the affected cylinder
http://www.stangnet.com/mustang-forums/threads/cylinder-balance-test.695039/
