missed shift results
  • Thread starter Thread starter twolo4u2c2
  • Start date Start date Dec 13, 2006
twolo4u2c2
5 Year Member
Apr 10, 2003
330
reading, PA
Dec 13, 2006
  • Dec 13, 2006
I tore my 347 apart after a missed shift and a loud knock at 1500rpm and so far I found 1 CYL with a loose piston...mabey a 1/16 inch or less up or down with a knock when hit the ball of my hand. The rest are quiet. once I get the other head off ill fill you in on that side. Hope I can save the block.....I should be able to right? any suggs?
thanks
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Dec 13, 2006
  • Dec 13, 2006
you should be able to save the block depending on why the piston is loose....if its a smoked bearing you should be fine...but if the wrist pin broke or something and chunked the bore than thats another strory...but im hoping for the best
JChalfan
551
Bellevue, WA
Dec 14, 2006
  • Dec 14, 2006
like dragnazz said, as long as long as the cylinder walls look fine, I don't see why you couldn't reuse the block. Once you get it all torn down, inspect it really well and make sure everything looks ok. You could always take it to a machinist and have them look it over too.
Jeff
blackened88lx
Connecticut
Dec 14, 2006
  • Dec 14, 2006
I see you have a 6al, where was your rev limiter set?? I hope most of the bottom end is okay.
twolo4u2c2
5 Year Member
Apr 10, 2003
330
reading, PA
Dec 14, 2006
  • Dec 14, 2006
well!!
its all my fault...I didnt have a chip in there. I KNOW I KNOW dumb a*s me and now i'm paying for it. I think the bottom end is fine because it ran fine just knocked and 1500 rpm. dose anybody know if the stroker kits use standard 302 bearings?
thanks
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
L
Engine Normal Leakdown Results (unstarted in nearly 2 years)
  • Lube
  • May 26, 2024
Fox 5.0 Mustang Tech Jun 1, 2024
Blackhawkxx
SOLD For Sale '92 LX Street/Drag car - WV
  • MikeyMustang
  • Apr 12, 2025
2K
Fox Body Mustangs For Sale (1979-93) Dec 31, 2025
MikeyMustang
Engine No start issue AGAIN!
  • ucnhtmenow1
  • Sep 1, 2024
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 11, 2024
89ripper
