Missing parts under hood
  • Thread starter Thread starter curtisboytejr
  • Start date Start date Jun 19, 2011
curtisboytejr
33
  • Jun 19, 2011
I had a engine warning light and i went and purchased a code reader and it gave me a code of 85 which is canister purge soleniod cicuit failure. So after i did a little research to find where the part is located and i go to the car and it is not even on the car. I cant even find the plug. I'm sure the plug has been cut off and is gone. I was hoping someone could tell me which wiring harness it was originally in. Picture would be great. 93 mustang GT
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 19, 2011
  • Jun 19, 2011
Code 85 - CANP solenoid - The Carbon Canister solenoid is inoperative or missing. Check vacuum lines for leaks and cracks. Check electrical wiring for loose connections, damaged wiring and insulation. Check solenoid valve operation by grounding the gray/yellow wire to the solenoid and blowing through it.
The computer provides the ground for the solenoid. The red wire to the solenoid is always energized any time the ignition switch is in the run position.
Charcoal canister plumbing - one 3/8" tube from the bottom of the upper manifold to the rubber hose. Rubber hose connects to one side of the canister solenoid valve. Other side of the solenoid valve connects to one side of the canister. The other side of the canister connects to a rubber hose that connects to a line that goes all the way back to the gas tank. There is an electrical connector coming from the passenger side injector harness near #1 injector that plugs into the canister solenoid valve. It's purpose is to vent the gas tank. The solenoid valve opens at cruse to provide some extra fuel. The canister is normally mounted on the passenger side frame rail near the smog pump pulley.
It does not weigh but a pound or so and helps richen up the cruse mixture. It draws no HP & keeps the car from smelling like gasoline in a closed garage. So with all these good things and no bad ones, why not hook it up & use it?
The purge valve solenoid connector is a dangling wire that is near the ECT sensor and oil filler on the passenger side rocker cover. The actual solenoid valve is down next to the carbon canister. There is about 12"-16" of wire that runs parallel to the canister vent hose that comes off the bottom side of the upper intake manifold. That hose connects one port of the solenoid valve; the other port connects to the carbon canister.
Purge valve solenoid:
The carbon canister is normally mounted on the passenger side frame rail near the smog pump pulley.
Carbon Canister:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Wiring & Engine Info Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
Mustang5L5
Mod Dude
Feb 18, 2001
43,369
18,116
224
Massachusetts
Jun 19, 2011
  • Jun 19, 2011
Find the ect sensor on the pass side of the motor. Right where the wiring for the ect sensor come out of the harness, is the wiring for thencharcoal canister as well. It's in the same tape out. From there, you can trace the wiring down to the canister mounted on the passenger side frame rail.
curtisboytejr
33
  • Jun 19, 2011
Thanks this will help a lot
curtisboytejr
33
  • Jun 19, 2011
I wonder why someone would remove it?
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
Jun 19, 2011
  • Jun 19, 2011
Its not uncommon for them to be missing. I think they usually get jerked out when people pull their emmissions and smog stuff; usually to just unclutter the engine compartment.
curtisboytejr
33
  • Jun 19, 2011
Thanks guys, i found it and it was right where yall said. I got to order me a new solenoid now and some tubing.
Mustang5L5
Mod Dude
Feb 18, 2001
43,369
18,116
224
Massachusetts
Jun 19, 2011
  • Jun 19, 2011
Which part is missing exactly? There should be two lines. One runs from the canister, to the rear of the car and gas tank. The other line comes out of canister, to the solenoid purge valve, then up to the intake manifold. This line is just standard vacuum line. Nothing fancy
curtisboytejr
33
  • Jun 19, 2011
The missing parts are solenoid purge valve and the tubing for it.
curtisboytejr
33
#10
  • Jun 23, 2011
  • #10
Hey guys, i need a little more help. I purchased the purge valve solenoid and it looks correct but it does have a different connector on it. I was wondering if there is another wiring harness in between the connector and the purge valve. thanks Curtis.
Mustang5L5
Mod Dude
Feb 18, 2001
43,369
18,116
224
Massachusetts
Jun 23, 2011
#11
  • Jun 23, 2011
  • #11
There is a short wiring harness that plugs up to the harness on the engine and extends down to the canister. It's about1.5 feet long. The solenoid connects at the canister
curtisboytejr
33
#12
  • Jun 23, 2011
  • #12
I went to pull-a-part and found one that was identical off of a 1988 5.0 crown vic. so i cleaned it up and going to install it tonight. Thanks guys
aar0s
1,015
55
69
Jun 23, 2011
#13
  • Jun 23, 2011
  • #13
not to derail, but where does the the HEGO ground at, number 19 in the diagram?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 23, 2011
#14
  • Jun 23, 2011
  • #14
On the intake manifold or the back of the cylinder head. If memory serves me correctly, there is a spot on the back of the cylinder heat that is used for the ground.
aar0s
1,015
55
69
Jun 23, 2011
#15
  • Jun 23, 2011
  • #15
I had my intake off last fall and dont remember any ground on it so its probably on the head. thanks, i bet that mine is covered in oil then!
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
A
2020 Ford Mustang GT P0036, P0138, P0141 02 sensor help
  • AmkoA
  • Jul 29, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 5, 2025
skkrtis
