5w-30 mobile one here.
a side note, use to run mobile one 15w-50 and after freshening the motor one winter found that my cromoly oil pump drive shaft was twisted. Came to the conclusion the oil was too thick causing excess loads on the oil pump. Also found that the thicker oil doesnt flow as well as the thinner, and since oil is suppose to lubricate and remove heat, I decide to switch to 5w-30, and in doing so the oil pump drive shaft and bearings look great after a few racing seasons, plus I picked up a few ponies with the thinner oil.
