Modifications to stock converter???
I have a question about torque converter work. There is a local transmission shop that specializes in custom torque converters. The guys there seem very knowledgable and I am considering letting them do some work for me. I enquired about a custom built converter, and their answer was to basically build a new converter based on modifications to my factory converter. I just wondered what everyones thoughts were on this? There seems to be some very good positives to this method:
1. maintains 12" diameter which would cut down on heat
2. maintains lock-up feature
3. custom stall based on existing vehicle modifications up to about 3300 rpms
4. Very cost effective
Don't get me wrong, I'm not trying to get off cheap, I just hadn't planned on getting into this type of modification yet because I thought it would be much more costly. However, the guy I spoke with said that many of the aftermarket companies have a huge mark-up on their products and in many cases they are doing exactly what he plans on doing by modifiying a stock converter. He mentioned 3 parameters that he could modify to adjust stall speed: modifications to the stator, fin angle inside the converter, and something called the A/B ratio I think. Anyway, he said he would make these modifications then tig weld in several areas inside the converter to reinforce and add to the overall strength of the unit and this would only set me back a few hundred dollars including installation. Almost sounds too good to be true, but seriously they sound like they know their stuff. Also, they have two pro-mod cars that they professionally drag race.
Give me your thoughts, I'm curious as to anyone that has gone this route.
Thanks
Thanks
