Modified Hydraulic Lifters
  • Thread starter Thread starter TenorPlayinGuy
  • Start date Start date Jun 22, 2007
TenorPlayinGuy
1,208
Canyon Country, Ca
Jun 22, 2007
  • Jun 22, 2007
I saw in some magazine article Either 5.0 Mustang , or Maybe Modified Mustang. About a budget build where they modified the lifters to not give as much under load of heavier spring rates at the valves.
Anyone have this article where they can tell me the steps or perhaps the size and quantity of washers needed. I would prefer to do this since I just upgraded the springs on my E7's and would prefer to take advantage of them. Thanks fellas. Or if you even have a web link for it I would great appreciate it. Thanks
Daniel
Rick 91GT
Mustang Master
95
99
PA
Jun 22, 2007
  • Jun 22, 2007
really not needed, and depending on what spring pressure you are talking about a stock lifter will work just fine.
If you really need to keep the lifter pumped up due to spring pressures look into gettting a set of restricted pushrods. We've run stock hyd lifters with over 250lbs on the seat to over 8000rpm..... Just need to know what you are doing.
TenorPlayinGuy
1,208
Canyon Country, Ca
Jun 22, 2007
  • Jun 22, 2007
Hmm... I know mine are old I just wanted to make sure they were going to stand up to the better springs.
TenorPlayinGuy
1,208
Canyon Country, Ca
Jun 23, 2007
  • Jun 23, 2007
??anyone??
Rick 91GT
Mustang Master
95
99
PA
Jun 23, 2007
  • Jun 23, 2007
If they are old, replace them..... To be honest any spring that would warrant the lifter modification has no place in a E7 head.
Use a stock lifter and you will be fine.. What's your seat pressure?
TenorPlayinGuy
1,208
Canyon Country, Ca
Jun 24, 2007
  • Jun 24, 2007
120# seat and 375# open pressures
Its the CraneCams 44308-1 kit
Rick 91GT
Mustang Master
95
99
PA
Jun 24, 2007
  • Jun 24, 2007
They will be more then fine on a stock lifter, I wouldn't worry about any lifter or restricted pushrods until you are up in the 145-160# or higher and are spinning 7500rpm.
TenorPlayinGuy
1,208
Canyon Country, Ca
Jun 25, 2007
  • Jun 25, 2007
Sounds good.
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
Engine 302 production block selection
  • FastDriver
  • May 19, 2024
  • 2 3
8K
Fox 5.0 Mustang Tech Jul 1, 2025
FastDriver
H
Drivetrain 4R70W clutch friction/metals/piston set up questions for transmission guru
  • Hizdudeness
  • Apr 4, 2024
Fox 5.0 Mustang Tech Nov 15, 2024
slow84lx
