modifying AOD
  • Thread starter Thread starter Foxfan88
  • Start date Start date Aug 13, 2005
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Aug 13, 2005
  • Aug 13, 2005
Hey, i mentioned my earlier that my AOD has some internal damage. We think that the spline shaft or something, that connects to the gear selector lever is twisted, so the whole angle of the lever is moved. My dad cut the shift cable bracket and it worked, all the gears work well but the cable pulls at the lever at such an angle that it cant get into Low 1. its like pulling it back when the lever needs to go at a 45 deg angle.
The AOD is fine except for this problem. But i dont want to mod this tranny if its like this. Would you suggest to just swap to 5 speed or buy another AOD.
I know a guy who has a 75k mile AOD with a transgo shift kit and he will throw in a TCI 3000 converter. I can get it for like 300 buck. BUT i dont know if our shift cable would work. since the bracket is cut about a inch shorter.
would an anti ballooning plate affect anything on a N/A car, his car had nitrous and he had the anti ballooning plate so ?????
M
macx
228
SE Missouri near Cape Girardeau
Aug 14, 2005
  • Aug 14, 2005
Here's a couple of bits of into that will
give you some info on a couple options.
http://www.lincolnsonline.com/article111.html
http://www.lincolnsonline.com/article80.html
Here's some misc related info
http://www.lincolnsonline.com/article48.html
http://www.lincolnsonline.com/article91.html
393Bird
244
Clarksville Tennessee
Aug 14, 2005
  • Aug 14, 2005
I would guess the shifter shaft and rooster cone that has the notches for the shift detents to match up are 1 tooth off on the inside of the trans. There is a 21 Mm nut holding it. To correct, you would drop the pan, loosen the 21Mm nut and move the rooster cone one notch, then retighten the nut.
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Aug 15, 2005
  • Aug 15, 2005
would that move the lever on the outside??
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
F
C4 Transmission
  • Fri Guy
  • Jan 23, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 23, 2025
LILCBRA
HP woes with Sniper Sytem
  • Stang_1973
  • Mar 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2025
revhead347
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
