modifying crossmember for TKO. help!
  • Thread starter Thread starter ShortThrow50
  • Start date Start date May 15, 2007
ShortThrow50
923
Pa
May 15, 2007
  • May 15, 2007
I didnt take notice how the crossmember sit while it was on the car. lol. Anyway does the higher hump go on the passenger side while the lower hump goes on driver side? Im pretty sure that the higher side is the passenger side. Just want to be sure. Next thing, Am i supposed to grind the tak welds off then slide it ALL the way back? Then throw a tak weld or 2 on? Thanks
oh, this is for a 1993 5.0 lx
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
May 15, 2007
  • May 15, 2007
Yes, grind the spotwelds down so it can slide back. Installed correctly the humps are designed to clear for the dual exaust so it should look like _/\__/\_ or something of that nature.
G
getusummm
156
  • May 15, 2007
I would set the cross member in place before tacking. You can slide it as needed, mark it, then remove and tack.
ShortThrow50
923
Pa
May 16, 2007
  • May 16, 2007
thanks guys for the replies. Does any one remember where the higher hump goes? one hump is higher than the other. I think the higher one goes toward passenger side
rd
3,316
63
109
Ocean Springs MS
May 16, 2007
  • May 16, 2007
Per the instructions on my new Ford FRPP crossmember, the higher hump goes on the passenger side.
ShortThrow50
923
Pa
May 17, 2007
  • May 17, 2007
thanks dude
D
Deleted member 87397
May 17, 2007
  • May 17, 2007
Yeah the tall hump on the pass. side and grind the welds then put it back up in there and slide the crossmember back until you get it to line up properly and mark it then re-weld.
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
Progress Thread "Alter Ego" White 1993 LX 5.0 5spd
  • idareu
  • Sep 9, 2024
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2025
idareu
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
