  • SN95 4.6L Mustang Tech
Mods on hold, its upkeep time
  • Thread starter Thread starter SilverBullet00
  • Start date Start date Aug 14, 2005
SilverBullet00
1,150
Wichita, KS
Aug 14, 2005
  • Aug 14, 2005
Instead of doing more mods I think its time for some upkeep on the mustang. It have an awefull delay in the acceleration for some reason so i hope to fix it. I was thinking of changing the plugs, pcv valve, fuel filter, brake fluid and coolant flush.. can anyone recommend anything else to do or suggest some good plugs for me to go with?
Also I was curious if I should go with an aftermarket plenum/TB. Sometimes when I stomp on it and I get a delay it seems like the motor is gasping for air.
Thanks!
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 14, 2005
  • Aug 14, 2005
I am glad to hear you are doing the brake fluid, many people never do it.
You might consider changing the diff fluid, how many miles do you have?
You should also clean your MAF.
You might also consider replacing the IAC, depending on milage.
Also, many step by step instructions to the things you are doing can be found on the Bullitt Archive.
One final thing, when you do the plugs, condition the rubber with silicone spray to get a nice watertight seal on the plug well and use silicone dielectric compound where the connection is made to the plug.
You are wise to spend money on preventitive maintenance instead of mods
SilverBullet00
1,150
Wichita, KS
Aug 14, 2005
  • Aug 14, 2005
Should I go with the copper plugs or platinum? and how exactly do I clean the MAF and the IAC? Do I just use carb cleaner??
Thanks for the replies!
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 14, 2005
  • Aug 14, 2005
It is all on the Bullitt Archive
Anyway, plugs - Motorcraft AGSF-32C (copper)
Use oxygen sensor safe spray cleaner on MAF or, even better, do it the way the Bullitt Archive says to...
tomustang
Psychotic Member
3,434
McLean Hospital
Aug 14, 2005
  • Aug 14, 2005
/peaks in
how bout that air filter?
SilverBullet00
1,150
Wichita, KS
Aug 14, 2005
  • Aug 14, 2005
well, I managed to clean that a couple weeks ago. Its really easy to do when its located in your fender well.....NOT! What a waste of 175 bux
However I did take off the whole system and put the stock intake back on and did notice a decress in performance....so I cleaned the filter real good and put it back on
I will check out bullitt archive!
anymore suggestions???
V_Eight
617
ATL
Aug 14, 2005
  • Aug 14, 2005
Engine oil and filter?
Tranny oil (fluid)?
  • Gulftown980x
  • Jul 29, 2026
squeak93
G
  • Poll Poll
I got a free Mustang from Grandma
  • GrannysMustang
  • Mar 4, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 6, 2026
Realmongo
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
9
96 mustang gt
  • 96projectgt
  • May 2, 2025
  • 2 3
2K
1996 - 2004 SN95 Mustang -General/Talk- May 15, 2025
96projectgt
9
