  • SN95 4.6L Mustang Tech
mongoose installation help
  • Thread starter Thread starter predator_96817
  • Start date Start date May 1, 2005
P
predator_96817
133
  • May 1, 2005
ok, i got started on my vortech mongoose kit and im stuck in a few places, i could use some help ....
1. The bypass valve hose that attaches to the nipple..where does it connect to? what do i do with the T connection.
2. Took me like 2 hours to get the belt on. it is SOO tight that there is NO slack on the tensioner at all. one of the ribs is not on the supercharger pulley neither and i cant get it on because there is no more slack and its really really tight. should i but a belt thats and inch longer?
3. I forgot what color wires goes on which side of the IAT sensor and i dont have the diagram anymore. which the clip up, which one goes where.
4. Spark plugs. what do these NGK's need to be gapped at (came with kit)
5. How in the world do you get the rubber sleeve over the Lightning MAF?
if anyone has a overview pic of a finished project for '03 - '04 that would help me out a bit
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 2, 2005
  • May 2, 2005
Try posting this in the Power Adders section. You may have better luck there.
yellow2kgt
175
Fishersville,va
May 2, 2005
  • May 2, 2005
I will see If I can help with a few answers.
1. That hose should connect to one of the RED lines that are after the throttle body. I spliced into a red line that ran to the sensor on the passenger side fuel rail.
2. Belts are a pain to install. The supplied belt should work. What pulley are you trying to slide it over last? I found it easiest to get the belt on all of the pullies except the power steering pump or the water pump(just pick a large pulley). Then have a buddy hold the tensioner(sp?) back while you slide the belt over the last pulley. But it will take some muscle.
3. I have no idea. My 2000 did not require any splicing.
4. .030 - .035
5. I am using the 80mm Lmaf so I did not have any issues. But you might try boiling the sleeve in hot water to help it stretch.
Evenflow
yellow snow cone lover
Nov 4, 2004
116
Mass
May 2, 2005
  • May 2, 2005
Why dont you just call Tim and ask for some help? Or try going to the MPH boards and asking there.
P
predator_96817
133
  • May 3, 2005
cool, everyone thanks for the help. i think i have all my problems figured out now. just that damn belt, everything is on but 1 rib from the supercharger pulley. think it will fall into place once i start the engine?
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
A
Procharger install/prep questions
  • ahratrew
  • Nov 22, 2025
SN95 4.6L Mustang Tech Nov 26, 2025
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
  • Gulftown980x
  • Jul 29, 2026
squeak93
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
