Gearbanger 101 said:This would be a good time to put your underdrive pulleys on Ebay, since you can no longer use them after the blower install.![]()
Sure.....15K is nothing. Put em back on and drive worry free.Stangdriver1119 said:Think its OK to stick my stock ones back in? I saved them after installing my Steeda UD's. My stock ones have about 15K on them.
shotime said:For those that have the kit, does it come w/ a recirculating valve to let off the boost pressure or is it a bypass that vents to the atmosphere(BOV)??
Also, when I talked to Tim he said 400 extra for the polished unit, all other places i've seen offer the poslished headunit upgrade for 150-200...just wondering if anyone knew.
Two more questions, what coating is on the MPH boost pipe and the ait inlet from blower to TB? Looks like the air inlet is bare aluminum and the boost pipe polished or ceramic coated??
Agreed.BennyDaBall said:And to clear something up, the INLET pipe is what the boost pipe replaces (BEFORE THE COMPRESSOR) and the DISCHARGE pipe is what connects the blower to the throttle body (AFTER COMPRESSOR). It's confusing, seeing as the discharge pipe is the one which actually holds the boost...
Reason for boost pipes being called boost pipes (or powerpipes) is because they actually increase the ammount of boost generated by the blower by allowing it to suck in a larger volume of air more easily from the atmosphere with their larger diameter and less restriction than the stock inlet peices.
ChrisGT said:I have a T-trim mongoose kit on my car with the MPH boost pipe. It's an automatic and I've pullied down to 12 lbs. of boost. I'm making 345/343 at the wheels.
Yes it includes a stock bosch bov from vortech. The MPH boost pipe has a silver finish on it. It doesn't come polished.
Stangdriver1119 said:What yr is your car and is it fairly stock? The numbers seem rather low to me and doesn't help my decision to get one lol
I would imagine your car was tuned with a veeeerrrry conservative A/F ratio as well. Even with an auto and 90* heat, your numbers still seem quite low for seeing 12psi. I would expect you're leaving about 30-40rwhp at the table in it's current state of tune.ChrisGT said:Automatics eat ALOT of hp. Do the math at the crank and I'm making over 410 at the crank.
Gearbanger 101 said:I would imagine your car was tuned with a veeeerrrry conservative A/F ratio as well. Even with an auto and 90* heat, your numbers still seem quite low for seeing 12psi. I would expect you're leaving about 30-40rwhp at the table in it's current state of tune.
ChrisGT said:![]()
this is true, but it's MPH's biggest selling point. Power AND reliability!
Fuel economy with either blower (Centrifugal or Positive Displacement) should be essentially unchanged when running around under vacuum. Only when manifold pressure becomes positive (under boost) does the computer order then need for additional fuel. Since both blowers utilize bypass valves, any unneeded airflow created during normal driving is re-circulated back into the system. These blowers typically take very little horsepower to turn otherwise, in a non-boosted state.JohnyD05 said:How has the mongoose kit affected your gas mileage? when driving decently. Just curious. Does anyone has some 1/4 times with the kit on a mostly stock car?
when do you feel the boost come on, i heard below 3000 rpm, you don't gain much power? just cause of the style of blower. I am torn between this blower and the KB, but i don't want to start that argument.
04YELLOWGT said:Just call an order it and tim will ask you what you have done to it. Then if you already have a tuner you can mail it to him and save about $250 and he'll ship it back. Thats what I did. When you go to dyno though he said with the autos you have to load one tune do a run then load the other. Something about locking up the convertor.
On the install I'll be able to tell you next Saturday. A friend of mine, anSVT mechaninc at ford, and me are going to the Shop and installing it.
