More A/C Woes
JC 25TH
41
Georgia
I am trying to locate the A/C drain hose on my 90LX. It is obviously clogged because it is leaking back in the the interior filling the pan and when I make turns it will come out on the floor. I have been searching all morning and some posts say it is on the drivers side some say its on the passenger side. Is it something I can see from above or do I have to crawl underneath the car? If someone has a picture that they can post that would be great. I see a rubber grommet almost directly underneath the lines for the heater core, but it is flat no rubber elbow like I have been reading about in other posts. Can someone point me in the right direction. Thanx.
On the passenger side firewall in the engine compartment you'll see a rubber grommet towards the bottom of the evaporator housing. There should be a very short hose sticking out of it. Obviously though, yours is not as you have a leak. Sounds like you may have to take the dash out and remove the evap. housing to fix it..... :notnice:
The drain going to the engine bayis on the driver's side firewall. It drips onto the stock header location. A straightened coat hanger should do the trick.
