More EFI problems
  • Thread starter Thread starter blue66tang
  • Start date Start date Oct 14, 2006
blue66tang
1,092
Medford, OR
Oct 14, 2006
  • Oct 14, 2006
I have more efi problems. I have all kinds of wiring diagrams for my 89 HO that i am putting into my 84 cj7. The problem is that a ton of wires are not matching up to my harness. I know i have a mass air harness yet all the mass air harness diagrams are not matching my harnes. Are some of the harneses different? My main engine harness has 2 8 pin connectors one is grey and one is black. These are not the 10 pin harnesses. All the diagrams i have says there should be only one brown harness. Does anybody know what harnnes i have so i can find the right diagrams. Im as frustraited as heck now.
Thanks
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 14, 2006
  • Oct 14, 2006
Try posting the wire colors. I do have a full 89 wiring diagram set that I would be glad to email you if I haven't already done so. I would need your email address since it is too big (2.5 Mb) to pass through Stagnet's email gateway.
Diagrams courtsey of FordFuelInjection.com
The following diagrams may not be the perfect match for yours, but they are typical of The EFI 5.0 Mustangs.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
blue66tang
1,092
Medford, OR
Oct 14, 2006
  • Oct 14, 2006
Thoes are the wire diagrams i have, i bought the helms 89 mustang book. I dont have that brown connector. In place of that brown one I have one black one and one greay one. Both are eight pin. So none of my wires match up to the wires that are in the diagrams. Im thinking that i have an early mass air harnnes. Like an 87-88 harness or something.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 14, 2006
  • Oct 14, 2006
Check out the AutoZone wiring diagrams. They may be able to shed some light on your problem.
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model Mustangs
vristang
4,933
101
124
Seattle
Oct 15, 2006
  • Oct 15, 2006
If the 89 diagrams don't match what you have then open your search to a year before and a year after.
My 90GT has a 91 wiring harness.
Only a couple of color changes and pin locations were different, so far as I could tell.
Boy was I confused though.
Good Luck
jason
tbovee
129
Fredericksburg Va
Oct 15, 2006
  • Oct 15, 2006
could it be a 90 harness? Isn't the air bag connector grey?
M
MatthewP
355
Calgary, Alberta
Oct 15, 2006
  • Oct 15, 2006
If you are talking about the two connectors that are on the driver's side near the firewall on the Mustang and connect the engine harness to the chassis harness, that sounds like a 1990 harness to me. The later harnesses use a single (brown) connector at that location.
This seems especially likely if your 89 Mustang was a late build date.
Good luck.
-Matthew
blue66tang
1,092
Medford, OR
Oct 16, 2006
  • Oct 16, 2006
Good luck.
-Matthew
That sounds right. Mine must be a 90. I think i have it all figured out now. Dang was it confuseing for a while. Seems pretty simple now. Only about 6 wires to hook up: fuel pump relay, water temp sending unit, oil pressure sending unit, and about 4 power wires. Does this sound right?
Z
Electrical Radio wiring diagram for 91 fox
  • Zeke1995
  • Jan 11, 2026
Fox 5.0 Mustang Tech Jan 12, 2026
Zeke1995
Z
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
