With a 347, I had to bore my motor 30 over and i have the gt40 x heads...I guess my compression is about 10 1/2:1...?...will i be fine to run a vortech s trim superchager with this???? What power would i make...guess....
If you run the blower on it I woul only run 5-8psi.
The block isn't going to handle that kind of power. Unless your running an aftermarket block.
Should be in the 500hp range.
I have a buddy doing the same thing. But he has and R302 block with the best of the best as far as internals. If you have the blower and everything allready I would say go for it. But the stock block will be on barrowed time.
