more pinging questions
  • Thread starter Thread starter 68GEETEE
  • Start date Start date Dec 28, 2003
68GEETEE
5 Year Member
Nov 21, 2003
481
Texas, USA
Dec 28, 2003
  • Dec 28, 2003
I backed off my timing, but still need to get a light and read where she is at. I understand the timing at full advance should not be more than 39-41. Is that correct? Secondly, how do I change the weights in the distributor to make it right? She isn't pinging right now, but I am not satisfied that my work is done.
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Dec 28, 2003
  • Dec 28, 2003
GET A LIGHT. and make shore the timing tag on the engine and damper are correct first. If its a stock or lightly modified engine on pump gas, I think that is to much total advance, depending on the cam and other factors. If you have a stock dist. with vacuum advance check that the pod isnt stuck or leaking. You can change the springs on the wieghts for faster or slower advance, a stronger spring means slower advance. Read up on timing before you play with it or you could cause alot of internal damage. Tell us what you have, there alot of smart racers here.
68GEETEE
5 Year Member
Nov 21, 2003
481
Texas, USA
Dec 28, 2003
  • Dec 28, 2003
I dont know what the previous owner did to the car. I do know about the .020 bore, it has a warmer than stock cam, I can hear it, but dont know the duration, lift, etc. Edelbrock manifold 4bbl Holley 600cfm, new distributor points and condenser. I have a feeling the vacuum advance isnt quite adjusted for this setup. I'll know more when I put a light on it to see where I stand. Are the weights easy to change? I have never done that before.
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Dec 28, 2003
  • Dec 28, 2003
On a early mustang distributor the weights are below the points plate. You must remove the dist. and take the gear off by taping the pin out. take out the points and condencer and screws. Push the shaft up through the dist body and the weights will come out with the shaft assembly. I have had weights that got so rusted they wouldnt move. Not an easy job for the amature.
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
