More power
stevesLX
373
cincinnati
O.K. guys need some help here. If you look at my sig or profile you will see what I have car wise. I am tryin to hit 12's on motor. My best time to date is a 13.29. I am looking for a very cheap and easy way to knock a few more tenths off. My setup currently is as follows: 89LX 302,Edelbrock 5.0 performer upper and lower,24# injectors, Fcam, 75MM TB, 73 MAF, Mac CAI, Lakewood 70/30 struts,Aluminum driveshaft, BBK long tube headers, 21/2 flowmaster exhaust, 3.73's, 245/45/17 Drag Radials. Some guys told me to take my belt off and it may break into the 12's. But thats a hassle to have to do that all the time, not to mention the car getting hot. I thought about perhaps a short belt but I tried to retofit one on there and it will not turn the water pump pulley like it should unless there's another trick that I am unaware of on routing it. I dont have A/C but I have power steering. I took the belt and stuck it on the crank brought it up the backside of the water pump pulley and around the alternator. But it barely makes contact with the water pump. Any suggestions would be great and much appreciated.
What kinda of 60' times are you running? I imagine with drag radials you are getting out of the hole pretty quick. I'm not sure there is going to be a cheap and easy way to get much faster on motor. I seriously doubt that taking the belt off would add that much horsepower to propel you 3 tenths faster in the 1/4. My guess is you are pretty close to your limit without some serious mods to the engine. You might want to look into suspension upgrades. Everyone decides to do those last for some strange reason.
Sub frame connectors migth help you out a little bit with getting those 60' times down a little bit. Perhaps upper and lower control arms out back. Every .1 off your 60' is approx .2 off your ET. So i would focus on suspension/Launch/shifting. Those are all pretty cheap mods that can net some nice ET gains. How much timing are you running...perhaps 93 octane and a couple more degrees?! What tire pressure are you running and what rpm are you launching and shifting at? What size drag radial?
I can get a set of GT40P for 140.00 from a junk yard up the street here but I am not sure if they will work with the headers I am using. I am using BBK long tube headers. I have heard people say the spark plugs go straight in instead of an angle. Any insight on this.
