More rearend woes!
MAXX RS4
83
Today I recieved my diff case and I have some simple questions..
1. Do the bolts that hold the ring gear into the diff case thread into the gear itself, or the flange on the diff case?
2. What should those bolts be torqued to?
3. Is there any way to tell whether those bearings that sit on the diff case are good/worn? Any tell-tale signs of a bad bearing?
Thanks!
__________________
ok so your using a new carrier. that part where the ring gear bolts to is the carrier. the case is the whole housing
the bolts thread into the ring gear, i would use new bearings, and they are pressed to the carrier. make sure you get new races for the bearings. never use old races with new bearings.
the tourqe spec for the ring gear bolts is 77 foot pounds.
Thanks man. It seems to me that you know your **** inside and out on these cars. Also, I surely need to update my terminology database :nice:
