MORE voltage problems....3g set up
  • Thread starter Thread starter jmd2914
  • Start date Start date Jul 6, 2009
J
jmd2914
937
Napa, California
Jul 6, 2009
  • Jul 6, 2009
I'm still having voltage problems with my mustang. i have a 3g on the car. voltage is fine when the car is warm and at idle, almost a bit on the low side, but whent here is load put on the car or the car is cold the voltage is way up at the top of the guage and about half the time the amp light is blinking. alternator is new ( bought it 2 days ago cuz my other one died) what can cause such high voltage?? i thought the regulator at first but its a new alt. its getting so bad it blew out my high beams when i turned them on. ( on a side note if my high beams dont work but my low beams do, replacing the bulbs will fix this right?)
thanks in advance for any help, im at my wits end with this one
J
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
281
134
Apache Junction, AZ
Jul 6, 2009
  • Jul 6, 2009
Defective voltage regulator. Take it back and have it bench-tested to verify.
TenorPlayinGuy
1,208
Canyon Country, Ca
Jul 6, 2009
  • Jul 6, 2009
yep, I remember swapping my alternator 4 times in one day, because if it wasn't the bearings, or rectifier, it was the stupid Diodes in the Regulator. It its going bad, your getting too many volts to your battery, and it will ruin that in the mean time.
Just because it's new doesn't mean it can't be bad. I now have all mine tested before leaving the store. It's easy.
J
jmd2914
937
Napa, California
Jul 6, 2009
  • Jul 6, 2009
alright i'll take it in and have it tested. Is there anything else other than the regulator that will cause such high voltage though?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 6, 2009
  • Jul 6, 2009
If the sense wire (yellow/white wire that connects to the D shaped alternator plug) has a bad connection, it could cause problems.
Disconnect the negative battery terminal and measure the resistance of the yellow/white wire wire from the tab to the starter solenoid. You should see less than 1 Ohm.
Diagrams courtesy of Tmoss & Stang&2birds
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds
(website host) for help on 86-95 5.0 Mustang wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 88-91 5.0 Mass Air Mustangs
Complete computer, actuator & sensor wiring diagram for 91-93 5.0 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 5.0 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
J
jmd2914
937
Napa, California
Jul 6, 2009
  • Jul 6, 2009
alright i'll check the wire when i get home from work. if i have a bad connection what would be my next step? ripping into the harness are replacing it?
HISSIN50
34
129
Jul 6, 2009
  • Jul 6, 2009
If the sense wire is open, the battery light illuminates.
If the wire is compromised (what Joe is talking about), it can cause overcharging. Simply check voltage at that wire (at the regulator. It's labeled A) vs your battery vs your charge stud on the alt. All should be within 1/2V (I don't like to see more than 0.2V difference)
J
jmd2914
937
Napa, California
Jul 6, 2009
  • Jul 6, 2009
so just to make sure i have this right, with everything still connected, check the voltage at the wire, the lug on the alt and the battery? and everything should be about the same? if that wire turns out to be bad, whats the best way to go about fixing it? just take the entire thing out of the wiring harness and replace it?
HISSIN50
34
129
Jul 6, 2009
  • Jul 6, 2009
Everything is connected and the car is idling (you can do it with the car off if you need, like if you're afraid to blowing lights and such).
The sense wire should be fine - it'd be a freak thing if it was compromised but not totally broken (to overcharge, there'd have to be a lot of resistance in the circuit, so the alternator thought there was a large voltage drop in the charge cable and upped the output). I suppose a partially burned fusible link on that wire could do it but I haven't seen that happen.
There's a bigger chance that the charge cable is actually dropping a lot of voltage and the regulator and sense circuit are doing what they're designed to do.
The charge cable should drop less than .5V (though anything over .2 is unacceptable to me). To test that, set your meter to 20 DC V. Then just put one meter lead on the charge stud and one on the solenoid. The voltage reading on your meter is the drop.
J
jmd2914
937
Napa, California
Jul 7, 2009
#10
  • Jul 7, 2009
  • #10
just to cover it even though this is a stupid question, the charge cable is the 4g wire connected to the lug on the back of the alt right? also im running ( if memory serves) a 150amp circuit breaker ( in place of the 150amp fuse) so the charge cable comes out of the alt through the circuit breaker then over to the solinoid. could that breaker have something to do with it? ( im gonna test all that has been talked about when i get home but im stuck at work all night so i figured id just ask as many questions as i can)
HISSIN50
34
129
Jul 7, 2009
#11
  • Jul 7, 2009
  • #11
You'll be testing that charge cable (the 4 AWG cable) and the circuit breaker (indirectly) when doing the drop test.
If you're curious, you can do the drop test on the circuit breaker itself (put one lead on each lug and see what your meter shows. It should be almost zero V). You can do this with the car running or off, but it's more useful to test when the car is running (and there's a load running through the cable).
J
jmd2914
937
Napa, California
Jul 7, 2009
#12
  • Jul 7, 2009
  • #12
i checked the voltage drop from the alt lug to the starter relay and if i did it right i had about
.8V
HISSIN50
34
129
Jul 7, 2009
#13
  • Jul 7, 2009
  • #13
.8V
That's unacceptable IMHO. Did you do the same test on your circuit breaker to see if that's where the voltage is dropping? In any case, start testing (using one lead on the alternator's charge post and the other lead on the location of your choice) to see where the voltage drops off.
J
jmd2914
937
Napa, California
Jul 7, 2009
#14
  • Jul 7, 2009
  • #14
i had my dad double check my work, when we checked the voltage drops again. things seemed to check out alright. however i noticed my posetive cable on the battery was loose. ( the two top screws that hold the cable to the lug.) i tightened them down just to make sure. would that cause overcharging inadvertantly?
HISSIN50
34
129
Jul 8, 2009
#15
  • Jul 8, 2009
  • #15
A bad battery connection can definitely cause an issue (I've seen it cause quickly fluctuating voltage output).
You have the battery connector where the raw wire sandwiches under a flat plate (with two bolts that hold the plate secure)? Those can be problematic in general.
J
jmd2914
937
Napa, California
Jul 8, 2009
#16
  • Jul 8, 2009
  • #16
yeah, when i bought new battery cables it came with one like that for the positive side and a regular one for a the negative side. what kind should i buy? on a side note i tightened those bolts down and the problem seems to be fixed
93 LX
3,081
Norwalk, CA.
Jul 8, 2009
#17
  • Jul 8, 2009
  • #17
http://cgi.ebay.com/ebaymotors/87-8...id=p4506.c0.m245&_trkparms=65:12|39:1|72:1171
I bought this and it is ford cables.. nice fit and work great...
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 8, 2009
#18
  • Jul 8, 2009
  • #18
Some help with wiring and grounds...
The secondary power ground is between the back of the
intake manifold and the driver's side firewall. It is often missing or
loose. It supplies ground for the alternator, A/C compressor
clutch and other electrical accessories such as the gauges.
Any car that has a 3G or high output current alternator needs
a 4 gauge ground wire running from the block to the chassis
ground where the battery pigtail ground connects.
The 3G has a 130 amp capacity, so you wire the power side
with 4 gauge wire. It stands to reason that the ground side
handles just a much current, so it needs to be 4 gauge too.
The picture shows the common ground point for the battery & extra 3G
alternator ground wire as described above in paragraph 2. A screwdriver
points to the bolt that is the common ground point.
The battery common ground is a 10 gauge pigtail with the computer ground
attached to it.
The clamp on with 2 bolts battery terminal ends are a know problem causer.
Anyplace you see green on a copper wire is corrosion. Corrosion gets in the
clamped joint and works its way up the wire under the insulation.
Avoid them like the plague...
Picture courtesy timewarped1972
Correct negative battery ground cable.
J
jmd2914
937
Napa, California
Jul 8, 2009
#19
  • Jul 8, 2009
  • #19
alright if i switch battery cables ( to a type other than the clap style) how do i connect the wires that are attatched to the positive battery cable?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 8, 2009
#20
  • Jul 8, 2009
  • #20
See Wire Terminals, Automotive Wire, Battery Terminals & Electrical Supplies for some ideas. Just remember that most of the audio grade plastic parts won't survive the under hood temperature, so mount them away from the heat of headers and radiator.
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Saturday at 5:19 PM
manicmechanic007
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
