most boost
  • Thread starter Thread starter ahuge1
  • Start date Start date Dec 23, 2003
ahuge1
208
LUBBOCK,TX
Dec 23, 2003
  • Dec 23, 2003
Hey bros whats the largest amount of SC boost i can run safely on 10:1
perkys stang
7,132
PA
Dec 24, 2003
  • Dec 24, 2003
all depends on the fuel...
ahuge1
208
LUBBOCK,TX
Dec 24, 2003
  • Dec 24, 2003
93oct
ahuge1
208
LUBBOCK,TX
Dec 24, 2003
  • Dec 24, 2003
93oct pump
blown1989saleen
1,397
oxford,pa
Dec 24, 2003
  • Dec 24, 2003
i wouldnt try more than 8psi, you can go higher but your tuning window is gonna be pretty small
TIMMY2734
1,330
Queens, NY
Dec 24, 2003
  • Dec 24, 2003
intercooled or not?
ahuge1
208
LUBBOCK,TX
Dec 25, 2003
  • Dec 25, 2003
TIMMY2734 said:
intercooled or not?
either
Stang6911
211
Amarillo, Texas
Dec 25, 2003
  • Dec 25, 2003
Just make sure you have the fuel and you can run alot. Upwards to 15# or more. You have to have enoough fuel, good tuning, and low timing, with high octane and that is the trick to HP, high compression with alot of boost, Tricky setup but if done right it is alot of HP!
89stang10sec
91
  • Dec 25, 2003
Is this a street car? 10:1 is a lot for a blown street car, you will have to keep a pretty safe tune on it. If it is a strip only car you will be alright.
SuperchargedB87
485
New Jersey
Dec 26, 2003
#10
  • Dec 26, 2003
  • #10
I would stay around 10psi for a street driven car. Just make sure you keep a good tune.
ahuge1
208
LUBBOCK,TX
Dec 26, 2003
#11
  • Dec 26, 2003
  • #11
well, i was set on putting a blower on it over nos, but this is a street car that will see the track abit, so maybe i would be better off with aa 150 shot..
what kinda HP diffrences are we talking abotu between 8psi and 150 shot
ahuge1
208
LUBBOCK,TX
Dec 26, 2003
#12
  • Dec 26, 2003
  • #12
ahuge1
208
LUBBOCK,TX
Dec 26, 2003
#13
  • Dec 26, 2003
  • #13
Anyone
Xtreme Limits
375
Hudson, Florida
Dec 26, 2003
#14
  • Dec 26, 2003
  • #14
get the charger if u got the $, then just buy heads down the road, with nitrous when its gone its " play time is over ". but Nitrous does have its place......use a 125 hp when you get the charger and race gaS
ahuge1
208
LUBBOCK,TX
Dec 27, 2003
#15
  • Dec 27, 2003
  • #15
8psi and a 125 sho????t, man i dunno about that. maybe a 50 shot or a 75
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
Fuel FMU stuck?
  • JD1964
  • Sep 16, 2025
Fox 5.0 Mustang Tech Sep 24, 2025
JD1964
