Nice motor, cleanly done up. I think I'd add some color to the valve cover fins and lettering. As for the aluminum waterpump, I've learned to save money going with a stock aluminum unit from the local parts house. Same internals as the aftermarket pumps. They can be had in low volume(high rpm), std and high volume if you know what to look for.
Either will do, the volume is dependent on the impeller size. Small is a low vol, the biggest is a high vol. The Low vol is listed as a high performance pump (usually) the high vol pumps are listed as "police. taxi and HD cooling" (one or all of the three)What do you look for. Cast impeller or bent steel?
sorry about the hijack
