Motor is complete
ac1122
538
NEW YORK
Motor is complete...Billitt Oil Pump Gears, Canton Road Race Pan, Mac Longtubes Jets Hot 2000 Coated, and of course Sean Hyland Stage 1 Cams...Cant forget the Dupicolor Red (I know it looks orange in pics)
Its 11s NA or Boost!
DerekStangGT said:
you betta change that sig boy. that beast aint bone stock no mo!!
The sig is a joke...After Stangnet added the sig limit I changed it
KJ Hoppus said:
better get some suspension and tires for traction or you not running any 11s NA.
Well Il post a video of me staright off the street no cooldown and down the track in street trim...
THIS IS ALL MOTOR ON 17 INCH DRAG RADIALS
BTW here is my real mod list
2000 Performance Red GT
MODS:
*01 COBRA MOTOR*Ported/Extrude Honed Intake*Jet Hot Mac LongTubes*Magnapack Catback*Magnaflow X w/Cats*Tremec 3650*03 Cobra Aluminum Flywheel and Clutch*Steeda TriAx*Steeda Pullies*Home Depot PowerPipe*Pro-M MAF*4.30 Gears*Moser 31 Spline Axles*Eaton 31 Spline Posi*Wicked Motorsports Chip*UPR UCA/LCA*Bullitt Suspension*Aluminum D/S*Driveshaft Loop*Nitto Drag Radials*Global West Subframes*Cobra R Hood*
Sequential Taillights*20% Tint*Chrome Bumper Inserts*
Now it will have QA1 K-Member, Canton Oil Pan, FMS Oil Pump and Billett Oil Pump Gears, Sean Hyland Stage 1 Cams and slicks
kirkyg said:
Sexy...as stated before its traction time :D
What else have you done to it besides cams? P&p heads?
Are you planning to spray or go boost or just stay NA?
kirkyg
Sold the spray...Saving for a Real Blower and a Forged Bottom End...Goal is 650RWHP+ with the Novi 2000
Lazer2KGT said:
Looks good Alex, What did you find that was causing your timing issue?
Scott
We took the whole thing apart...The motor itself was off by 8 Degrees...We set it up according to specs...
Also the SHM Cams were off as well Not ground to the specs we asked for(After speaking with the people at L&M engines we determined we should still make good power)
Just alot of issues with the whole setup. Im glad its almost all over...Its gonna get dyno tuned now, I've had good luck with the JMS chip but now I need it perfect.
I will post Dyno #s when Im done...im hoping to see over 350 to the wheels
Looks good man. I like the red coil covers, I painted mine Ford Blue but they don't match the Laser Red real well. So did you completely tear it down and go threw the hole motor? That 1/4 mile pass looks strong. Congrats.
Scott
