Motor mounts
  • Thread starter Thread starter 65fastbackresto
  • Start date Start date May 30, 2007
65fastbackresto
1,229
AR
May 30, 2007
  • May 30, 2007
changing 6 banger out of 65 stang to 302, been looking at these motor mounts in some catalogs. Is it just 3 pieces? Motor mount, frame mount, and rubber insolator thing?
Looks like gonna cost me over $200 bucks, any cheaper way to do the same job?
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
May 31, 2007
  • May 31, 2007
A salvage yard will save you a bunch of money. The frame part of the mount hardly ever has any wear or damage so they can be purchased used. For motor mounts, compare the catalogues with places like Advance auto, Autozone, RockAuto.com and O'Reillys.
65fastbackresto
1,229
AR
May 31, 2007
  • May 31, 2007
My freaking wheels aint gonna work
17 by 9.5 inch American Racing wheels, pretty, but too big for this car. They rub pretty much everything.
65 Stang what backspacing is correct and how wide a wheel can I run, I`m guessing no more then 8 wide, not sure though.
65mistress
405
Generica USA
May 31, 2007
  • May 31, 2007
Dodgestang has a wheel chart on his site.
Is it true that the 66 V8 motor mounts are 1" taller or move the engine up 1" vs. the 65 motor mounts?
M
mustangdave
2,976
North Carolina
May 31, 2007
  • May 31, 2007
I don't know if this thread is a about motor mounts or wheels, but yes, sometime in 66, they changed the mounts. There are mounts made for 65-68 and I would guess they are the later style although there were several versions from Ford in those years.
65fastbackresto
1,229
AR
May 31, 2007
  • May 31, 2007
Sorry I ment to start a new thread
On the wheel thing. But I think your right about the 66`s raising the motor an inch.
SoCalCruising
2,437
SoCal
May 31, 2007
  • May 31, 2007
Yes, 66 mounts are higher. Take care if you get headers. Some will not fit with the early mounts. It may take a call to the manufacturer to find this out, but you should check.
Based on the use you have described earlier, I would go with a 7" rim on front with 4" backspacing. You can use an 8" on the back with 4.5" BS. I swapped my 225/50-16s up front for 205s and never looked back. It drives better with the narrower tire and I don't miss any traction on the twisties, even when driven spiritedly. I'm sure that there is a difference ... I'm just saying that it isn't much, and on the street you are unlikely to notice anything, at all. A 225/50-16 on the rear is a good size - looks good and gives decent traction. We don't drive these cars enough to NOT have the tires go hard before they are worn out (usually), so get a sticky tire (poor wear rating) like the Kuhmo ECSTA MX tires, or similar 200-220 rated tire (wear rating). Those Kuhmos really stick.
Another thing: if you keep the tire on the rear at the size recommended, you are unlikely to break anything in your drivetrain. The tires will break loose before anything else breaks. It's a nice safety precaution. Besides, it's easier to chirp in 1-2 shifts with your C4.
65fastbackresto
1,229
AR
May 31, 2007
  • May 31, 2007
Mine aint driven too much either
Spend too much time working to get much of anything done. I love the stance my car has now, it has P215/50/R17`s on it, and I`d like it to look pretty much the same. But without the tire rubbing its doing now, I cant even get 4 people in the car or the back tires rub the fenderwells when I hit a bump.
But I`ve got 4 1/4 inch backspacing, and there aint much room between the leaf spring and the tire now, 4 1/2 would be real close.
I like the sticky tire idea though, never thought of that.
Where can I find Dodgestangs website?
geostang351
946
Danb., CT
Jun 1, 2007
  • Jun 1, 2007
http://www.dodgestang.com/mustang.htm
C
chromedog
554
worlds center for speed
Jun 2, 2007
#10
  • Jun 2, 2007
  • #10
the 66 mounts are DEFINITELY taller than the 65's... my 65 l6 to V8 conversion with the 66 mounts raised the engine (351w) to a point that, with a wiend stealth intake, the aircleaner (cobra oval, 1 1/5 " tall) hit the underside of the hood... hello fiberglass shelby hood!
L
New here from Maine
  • lobster
  • Mar 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 5, 2026
lobster
L
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
