motor problems need help
well last saturday when i was on my way home from somewhere,i wanted to use my nitrous so i did and when i did it went BOOM!!,and blew my intake to peices and melted two of my spark plugs and i just replaced it and now its makeing a weird tapping or scratching noise,and one of my plugs has oil all over it,and i did a compression test and that cylinder had no compression??? does that sound like i broke a ring??
any other ways to check for bad motor...i really appreciate the help guys
97gtblue said:
.....i did a compression test and that cylinder had no compression??? does that sound like i broke a ring??
Compression test is as good as it gets. Sounds to me you like have a busted piston. Time for a rebuild or a used PI engine. In the long run those nitrous kits are not cheap.
