  • 1994 - 1995 Specific Tech
Motor Shaking Badly
  • Thread starter Thread starter rude_life
  • Start date Start date Dec 12, 2005
1 of 2 Next Last
rude_life
372
  • Dec 12, 2005
Hey guys i havent been on in a while i hope everyone's doing great..Ive got some issue's with the stang...Anybody know why my motor shakes so bad? It shakes so bad that my shifter and my whole car rattles and its very uncomfortable to drive..I look at my motor and it just shakes all over the place. Not just at idle though..I wont even go full throttle because it rattles so bad i feel like somethings going to break..Its very annoying. I have jacked my car up and looked at my Harmonic balancer several times but i cant see any rubber coming out anywhere.
Thanks guys..as always
Kris
HISSIN50
34
129
Dec 12, 2005
  • Dec 12, 2005
Kris, does it do it while you are stationary (not moving, but revving the motor in neutral) or only while actually driving down the road.
Knowing that helps isolate the rotating drivetrain from the motor.
Good luck bud.
rude_life
372
  • Dec 12, 2005
It does it while im in neutral and while im driving.
maypo59
194
Central Kentucky
Dec 12, 2005
  • Dec 12, 2005
check your harmonic balancer.
SuperDust22
The Power of Pixie Dust?!
Oct 19, 2003
1,821
Gilbert,AZ
Dec 12, 2005
  • Dec 12, 2005
harmonic balancer
and check your spark plugs
Dustin
BlackVert
5,589
9
98
Bethesda, MD
Dec 12, 2005
  • Dec 12, 2005
:SNSign:
W
Westee
36
  • Dec 12, 2005
check balancer and motor mounts
HISSIN50
34
129
Dec 12, 2005
  • Dec 12, 2005
Agreed. If it does it stationary, then the balancer is worth checking again. You can run a cylinder balance test to rule out a serious misfire.
Good luck.
blazrrr
15
  • Dec 12, 2005
I second the motor mounts.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Dec 12, 2005
#10
  • Dec 12, 2005
  • #10
If you bring up the rpm's easy from idle .............
and still get the vibes ...........
that ought to rule out the mm's!
Grady
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Dec 12, 2005
#11
  • Dec 12, 2005
  • #11
Have you checked your balancer while the car is running? If it's bad you should be able to see it shaking pretty badly. I looked at mine while the car wasnt running, and I couldnt find any rubber sticking out of it, pulled it off and then saw 1/2 of the rubber was missing.
rude_life
372
#12
  • Dec 12, 2005
  • #12
Hey guys..Well i took it to my buddys shop..Mikes Performance Automotive in Lancaster, CA..No rubber showing..The harmonic balancer has slipped within itself and the 0 degree mark is not lined up with the hole anymore
HISSIN50
34
129
Dec 12, 2005
#13
  • Dec 12, 2005
  • #13
Glad you got it figured out Kris.
rude_life
372
#14
  • Dec 13, 2005
  • #14
Thanks guys..Much appreciated, hopefully she doesent give way before i replace it...Can't my bottom end blow if that happens?
HISSIN50
34
129
Dec 13, 2005
#15
  • Dec 13, 2005
  • #15
Absolutely Kris. I really would try not to drive it at all till the balancer is fixed. Borrow money if you have to, but get it replaced very very soon.
Good luck.
a50sn95
368
Elk Grove, CA
Dec 13, 2005
#16
  • Dec 13, 2005
  • #16
You mean like this?:
DON'T DRIVE IT.....
Balancer spun at 4500 rpm's....
rude_life
372
#17
  • Dec 13, 2005
  • #17
Well..It has been shaking like that for a good three to four months..So is the crankshaft "un-balanced" being that it is making the whole car shake? Am I causing damage to my engine driving it under these conditions? What all is involved in the replacement of a harmonic balancer? What will I need to buy?
a50sn95
368
Elk Grove, CA
Dec 13, 2005
#18
  • Dec 13, 2005
  • #18
DON'T DRIVE IT....
It's not a hard job, you need a balancer, can borrow/rent the removal tool, and a big 15/16's socket and a breaker bar to get the bolt out. Hopefully it's a stick.
A search on balancer will find LOTS of threads....
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Dec 13, 2005
#19
  • Dec 13, 2005
  • #19
I'm with the others here!
QUIT DRIVING IT!!!
then again .......... if it has been doing it for that long.
you possibly could have done some damage to your main & rod bearings.
You just need to fix it ...... right away!
Grady
HISSIN50
34
129
Dec 13, 2005
#20
  • Dec 13, 2005
  • #20
It is not so much that the crankshaft is unbalanced - the H. damper quells torsional vibration (the fact that it is wrongly referred to as a 'balancer' can confuse its purpose).
When the piston explodes downward, it applies a torsional force against the crank, which can cause deflection and vibration or harmonics. The HD can help quell those vibes.
Grady, did you ever wrench on any old Triumphs? At higher RPM's the cam deflection was so bad that the ignition timing was all over the place. Thinking about this stuff reminded me of that for some reason.
1 of 2 Next Last
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
Motor ID
  • 65er
  • Mar 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 14, 2026
L
1996 harmonic balancer crank bolt. Help!
  • Lost in Palm Bay
  • Jul 21, 2026
SN95 V6 Mustang Tech Jul 24, 2026
Lost in Palm Bay
L
