Engine Motorcraft Distributor Help
if the parts store says it fits it probably fits. I just got a motorcraft cap from advance for $17, cheaper than the BWD one. They wanted $33 for the rotor though!!!
Yes but its not the cap its the plastic ring under the cap . They call it an adapter. Motorcraft is $77 on E Bay.....$17 for BWD. It looks the same If I knew how to put a webpage on here I would. I will ask them at Advanced
Just check the fit of your cap once the adapter is all tightened down to your distributor. The BWD ones are hit/miss as far as quality, and they seem to have some warpage where the cap will rock back-n-forth on the adapter once it's tightened down. I've run in to this more than once but luckily Advance Auto kept taking them back until we finally got a good one.. I checked the fit of my cap at the store and it fit well, but once tightened down the adapter warpage was evident. We even tried their own caps with the same result.
I just went through this debacle a while back. I even got a rebuilt Motorcraft dizzy that had the shaft hole drilled off center in the body. The rotor was hitting the terminals on one side of the cap. Took quite a bit of head scratching to figure it all out.
Parts stores suck.
Doing it this weekend. Thanks for the advice and I will know soon.It must be a popular part if they have it in stock Going to get it later , but its my wifes birthday weekend so she needs the attention . She gets pissey if I am putting my stuff first. Thats thirty five years of marriage.
