  • SN95 4.6L Mustang Tech
Mountaineer 4.6L
  • Thread starter Thread starter apats77
  • Start date Start date Sep 5, 2011
apats77
178
Watertown, MA
Sep 5, 2011
  • Sep 5, 2011
I have an 04 Mountaineer motor. Since its a PI motor, are the Heads and Cams compatible with my 97/98 NPI motor?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Sep 5, 2011
  • Sep 5, 2011
Yes, but odds are that has an aluminum block which would knock about 100lbs off the front end of your Mustang and help handling tremendously.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Sep 5, 2011
  • Sep 5, 2011
Is there anything wrong with the donor motor? If not, why not swap the whole motor? If this is an WAP block, you will love the weight savings.
apats77
178
Watertown, MA
Sep 5, 2011
  • Sep 5, 2011
the motor was pulled because it had a "bad rapping sound". Thats all i know about the motor, yes it is an alum block.
I just finished doing an engine swap (npi to npi) I dont have the time or shop anymore to do another swap.
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
Valve hitting piston?
  • krazedstang
  • Jun 9, 2025
SN95 4.6L Mustang Tech Jun 12, 2025
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
