Mr. Freeze bottle mounting issue
reeber
574
26
38
Berlin, NJ
Has anyone installed the Mr. Freeze kit on a '96 and up kit? Where did you mount the bottle. I am having fitment problems with a place to mount mine with the Vortech blower. Any help?
Ok wasn't that the kit some Magazine used? and if so I remember them using the washer fluid tank. They put the fitting in the bottom of the washer fluid tank, they also said washer fluid was 30% methanol but I'm not sure on that.
I made a bracket to attach mine to the power steering resevoir bracket. Go to the hardware store and buy a small L bracket and bend it into the shape you need it. Then drill a hole on each end. I don't know if you have the same room in that spot for the assembly as an 01, but I bet you can find somewhere with an extra bracket to help. Good luck.
