MSD 6AL-2 mounting: Is it ok to mount the box in the trunk?
Methodical
1,192
11
59
Clinton, MD
Also, is there anything I should be aware of if mounted in the trunk other than increasing wire size.
And can I mount the box upside down on the factory amp/speaker box in the trunk or is it a must to mount it right side up?
Thanks
I spoke with MSD tech and was told that it can be mounted upside down or anyway for that matter as long no liquid can get inside. And to keep the coil wires away from any item that may be affected by the high outputs (i.e. speaker wires etc.) and although the instructions says that you can ground the unit to the block, the tech was very specific about connecting the ground wire to the "-" post of the battery, which I intended to do anyway but just an FYI.
Thanks for the responses
