msd 6al buzzing (UPDATE)Daggar!
chobracobra
175
jersey shore
I dont know who read my threads about the buzzing coming from the msd box...but i called msd and they said humming and buzzing is normal and is from the different types of metals on the capacitor and tranformer changing shapes rapidly. I knew my grounds were good :)
So did they also tell you that the buzzing throughout your electrical system was normal? I mean... regardless of what noise the thing makes on it's own, it still shouldn't be feeding noise to your speakers.
Simple to do, but maybe hard to find parts for...
What you need are two things:
1.) a feed through filter capacitor - it filters noise off the power input. They come in two styles, one with a screw connection on each end and a metal band clamp around the middle, and with a pigtail and metal band clamp around the middle. Check your local auto stereo shop first. Put one filter cap on the power input of the MSD and one on the power input of the radio & amp.
2. Shield the wire going to and coming from the MSD box. The shielding can be either the flexible expanding braid type that is similar to what is used on stainless steel hose or shieilded power wire. Any good electrical supply should have it. Be sure to ground the shield at one end.
See http://www.wicksaircraft.com/catalog/product_detail.php/pid=1772~subid=610/index.html
yea i think radio noise is unnavoidable. there are many ways to avoid it, but when installing a high voltage electrical system there are not many options except the 25 dollar msd noise filter. Anyway for anyone else experiencing radio noise, the biggest ways to avoid them are
1. if you have two amps, ground them seperatley, not together!
2. Run you power cables on drivers side, and RCA wires on passenger side.
3. If you have to cross the two wires, make them perpindicular to each other not paralell.
4. Double check grounds
5. Check grounds again
6.Add more grounds
:flag:
