multimeter question and tps sensor
  • Thread starter Thread starter noslow1986
  • Start date Start date Nov 19, 2006
N
noslow1986
274
oswego Il
Nov 19, 2006
  • Nov 19, 2006
ok what setting do u have a multimeter on to tests tps sensor is is 20 or 2000 dc when i do this i get a reading of .05 is my tps junk or do i got something wrong
Mustang5L5
Mod Dude
Feb 18, 2001
43,382
18,125
224
Massachusetts
Nov 19, 2006
  • Nov 19, 2006
Those settings just state the max voltage it will display so it can set the decimal point.
WIth a car with a 12v system, you can leave it set to 20v since nothing will be over 20V on the system.
nitrous_bob
45
st clair shores MI
Nov 19, 2006
  • Nov 19, 2006
are you hooking the + to the green ?
and don't hook the - to the black wire, go black directly to ground, it will make a diff on the setting.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 19, 2006
  • Nov 19, 2006
Wrong answer.
The black/white wire is the signal ground: use it whenever you make voltage checks on any of the sensors (TPS, EGR, MAF, ACT, ECT). The computer references all the sensor input to this ground and not battery ground. The difference is usually only a .05-.1 difference, but that is important to the computer.
Try this... Currently there is some dispute about setting it at .99 volts being worth the effort, but anything less is probably OK. All you need is less than 1.0 volt at idle and more than 4.25 at Wide Open Throttle (WOT). Somewhere between .70 and .99 is the best range. You'll need a Digital Voltmeter (DVM) to do the job.
The Orange/White wire is the VREF 5 volts from the computer. You use the Dark Green/Lt green wire (TPS signal) and the Black/White wire (TPS ground) to set the TPS. Use a pair of safety pins to probe the TPS connector from the rear of the connector. You may find it a little difficult to make a good connection, but keep trying. Put the safety pins in the Dark Green/Lt green wire and Black/White wire. Make sure the ignition switch is in the Run position but the engine isn't running.
Here’s a TPS tip I got from NoGo50
When you installed the sensor make sure you place it on the peg right and then tighten it down properly. Loosen the back screw a tiny bit so the sensor can pivot and loosen the front screw enough so you can move it just a little in very small increments. I wouldn’t try to adjust it using marks.
(copied from MustangMax, Glendale AZ)
1. Always adjust the TPS and Idle with the engine at operating temp. Dive it around for a bit if you can and get it nice and warm.
2. When you probe the leads of the TPS, do not use an engine ground, put the ground probe into the lead of the TPS. You should be connecting both meter probes to the TPS and not one to the TPS and the other to ground.
3. Always reset the computer whenever you adjust the TPS or clean/change any sensors. I just pull the battery lead for 10 minutes.
4. Check the procedure for your year, on my 90 I have to turn the idle screw until it just touches the tab, then insert a .010 feeler gauge and give it about one more turn.
HISSIN50
34
129
Nov 19, 2006
  • Nov 19, 2006
JR, as always, is right-on.
You want to 'see' what the computer is seeing. And if the computer's sensor ground is tainted, you want to see that in your testing.
Ohming out the supplied TPS ground is never a bad idea if one has reason to question it.
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
TPs sensors different?
  • Creomod
  • Sep 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 11, 2026
DadLife0724
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
