Mustang 2003 GT - Oil Pressure Switch Failure and (SCP) Data Link Fault
Jackson1992
Mexico, MO, USA
I have a U1262 (SCP) Data Link Fault and C1284 Oil Pressure Switch Failure. These codes existed since May 29th. My Mustang is stock except for the cold air intake which was installed in 2012 and also added Reverse Glow Gauge which now needs to be replaced since its not glowing anymore. Any help is appreciated. Repair report below.
C1284 Code Definition
Oil Pressure Switch Failure\nNote: This code may not be valid. Re-run the Self-Test with the vehicle running to verify the code.
*3 Frequently Reported Fixes
-Replaced Fuel Pump w/U1043
-Replaced Fuse #34 w/B1681, U1043, U1262
-Replaced Fuse(s) w/B1681, U1043, U1262 (In progress - Replacing all)
U1262 Code Definition
SCP Communication Bus Fault - Perform Network Communications Test
*2 Possible Causes
-Invalid Data: Data transferred in normal inter-module messages with know invalid data. Transmitting module will set the code.
-Missing Network Data: Missing messages fault logged by a module upon failure to receive a message from another module within a defined retry period.
*2 Top Reported Fixes
-Replaced Antilock Brake System (ABS) Control Module
-Replaced Powertrain Control Module (PCM)
*5 Frequently Reported Fixes
-Removed Aftermarket Performance Chip
-Repaired Powertrain Control Module (PCM) Wiring
-Repaired or Replaced Electronic Brake Control Module (EBCM) Connector
-Replaced Instrument Cluster w/U1147
*15 Other Reported Fixes
-Replaced Alternator (Replaced July 2016)
-Replaced Constant Control Relay Module (CCRM) w/ U1147
-Repaired Data Line Wiring w/U1147, U1243
-Replaced Differential Pressure Feedback EGR (DPFE) Sensor w/U1147, U1243
-Repaired Differential Pressure Feedback EGR (DPFE) Sensor Wiring w/U1147
-Tightened Electronic Brake Control Module (EBCM) Connector
-Rehomed Electronic Brake Control Module (EBCM) Connector
-Replaced Fuel Rail Pressure (FRP) Sensor w/ U1147, U1243
-Replaced Fuse #21 w/B1681, P1260, U1043...
-Replaced Fuse #34 w/B1681, C1284,U1043
-Repaired Fuse Box Terminals w/U1147
-Replaced Fuse(s) w/B1681, C1284,U1043 (In progress - Replacing all)
-Repaired Ground G103 w/U1147
-Repaired Ground G104 w/U1147
-Replaced Powertrain Control Module (PCM) Connector(s) w/U1147
  • Sponsors(?)
Jackson1992
Mexico, MO, USA
Hello again.
I have a C1225 - Brake Warning Indicator Output Short Circuit To Battery. Last reported June 12th. No further info on how to fix.
Any help appreciated.
Jackson1992
Mexico, MO, USA
I have the following codes:
B2486 - No Code Definition Available (6/13/2018)
B1869 - Lamp Air Bag Warning Indicator Circuit Failure (6/16/2018) - No reported fixes
B1681 - No transceiver signal received from the module/no transceiver detected (6/29/2018) - Read below for reported fixes
The B1681 code appeared after a minor parking lot accident yesterday so I now have a huge impact on my bumper below the left tail light assembly. I also would like to know where the location of the transceiver is.
B1681 Code
*1 Frequently Reported Fix
-Replaced Passive Anti-Theft System (PATS) Transceiver
*7 Other Reported Fixes
-Removed Aftermarket Amplifier Wiring
-Replaced Fuse #21 w/P1260, U1043, U1147...
-Replaced Fuse #34 w/C1284, U1043, U1262
-Replaced Fuse(s) w/C1284, U1043, U1262 (In progress - Replacing All)
-Repaired Passive Anti-Theft System (PATS) Transceiver Wiring w/ P1260
-Replaced Powertrain Control Module (PCM) w/ P1260
-Replaced Transceiver
wmburns
SN Certified Technician
Aug 14, 2009
5,838
505
194
Houston Texas
I would love to help you. The first piece of advice I'm going to give is "stop replacing" parts as a trouble shooting method. Things like changing fuses just don't make sense. Test them.
Test the alternator. Test the battery.
Please re-state the car's current symptoms.
I'm going to assume that the car is a crank with no start. So let's start by CONFIRMING power into some key fuses. Test fuses F2.34, F2.2 and F2.8 for key on power using a known good ground. What to do next depends upon the exact test results.
1999-2004 BJB CJB fuse panel layout:
https://www.allfordmustangs.com/for...r-swap-wont-fire-please-help.html#post2669271
1996+ Crank with no start check list
https://www.allfordmustangs.com/forums/4-6l-tech/336452-1997-mustang-wont-ignite.html
Howto perform charging system voltage drop test
https://www.stangnet.com/mustang-fo...perform-charging-system-voltage-drop-test.56/
OBTW, the code about the oil pressure switch doesn't mean a thing and happens on every car where the motor isn't actually running.
Thread starter Similar threads Forum Replies Date
L 2003 V6 Mustang Oil Leak Above Oil Filter SN95 V6 Mustang Tech 1
Jriess 2003 Mach1 Mustang Oil Cooler SN95 4.6L Mustang Tech 1
S 2003 Mustang adjustable illumination fuse keeps blowing SN95 V6 Mustang Tech 1
J 2003 Mustang Brakes Pulling The Welcome Wagon 4
J 2003 Mustang Brakes Pulling 1996 - 2004 SN95 Mustang -General/Talk- 0
W Mach1 2003 coolant leaking rear of engine SN95 4.6L Mustang Tech 2
D Progress Thread 2003 mustang gt Rebuild 1996 - 2004 SN95 Mustang -General/Talk- 10
94chirps 2003 Mustang door speaker plug Mustang Sound & Shine All 1
H 2003 mustang v6 tick on start ups. SN95 V6 Mustang Tech 5
T No power to the MAF Sensor 1996 - 2004 SN95 Mustang -General/Talk- 0
nathanruschill 2006 Mustang GT mach 1 tribute 2005 - 2014 S-197 Mustang -General/Talk- 8
M 2003 GT auto shifting SN95 4.6L Mustang Tech 0
94chirps 2003 Mustang radio install Mustang Sound & Shine All 0
C Hi guys i just got a 2003 mustang gt 4.6 how do check kow it the car has pi heads SN95 4.6L Mustang Tech 6
F Electrical 2003 Mustang GT - Brake and Blink Fuses Blow SN95 4.6L Mustang Tech 7
P 2003 mustang GT cranks but doesnt start 1996 - 2004 SN95 Mustang -General/Talk- 3
Harveyj1965 Hello my name is Harvey my question today is under the hood fuse box I have a 2003 mustang GT edition centennial convertible under the hood fuse bo 1996 - 2004 SN95 Mustang -General/Talk- 0
H 2003 Mustang GT 4.6L Intake Manifold leak SN95 4.6L Mustang Tech 0
C Theft sign solid; car won’t start. SN95 4.6L Mustang Tech 2
C SOLD 2003 SVT Mustang Cobra, Sonic blue SN95 Mustangs For Sale (1994-04) 9
L 2003 mustang gt 1996 - 2004 SN95 Mustang -General/Talk- 8
F For Sale 2003 Mustang GT Vert with very low miles (21K)-Well taken care of SN95 Mustangs For Sale (1994-04) 1
K Clutch Squeal when clutch pushed in 1996 - 2004 SN95 Mustang -General/Talk- 1
P 2003 mustang 3.8L v6 1996 - 2004 SN95 Mustang -General/Talk- 0
F Anybody have experience changing halogen headlights to HIDs or LEDs? 1996 - 2004 SN95 Mustang -General/Talk- 3
03GThoopty Progress Thread 2003 Ford Mustang GT Build Log 1996 - 2004 SN95 Mustang -General/Talk- 101
J Paint and Body What is the hood of a 2003 mustang gt made of? 1996 - 2004 SN95 Mustang -General/Talk- 1
S For Sale 2003 Mustang gt wheels Wheels Tires Brakes 1
0 2003 Ford Mustang V6 3.8L gets around 12mpg and seems to shake a bit when started cold and has a bad rough idle when warm SN95 V6 Mustang Tech 5
N Deciding on which rims and tires to buy so there is no gap in the wheel well. 1996 - 2004 SN95 Mustang -General/Talk- 0
F 2003 Mustang GT not starting 1996 - 2004 SN95 Mustang -General/Talk- 3
A 2003 GT 4.6 - Best exhaust from 3 options 1996 - 2004 SN95 Mustang -General/Talk- 3
R Progress Thread 2003 Ford Mustang 1996 - 2004 SN95 Mustang -General/Talk- 1
O 2003 Mustang GT bogging down 1996 - 2004 SN95 Mustang -General/Talk- 3
B new to me 2003 Mustang GT 1996 - 2004 SN95 Mustang -General/Talk- 0
W For Sale 2003 GT Mustang Deluxe - $6500 (Orlando, FL) SN95 Mustangs For Sale (1994-04) 0
E Rear Lights w/Amber Turning Signal 1996 - 2004 SN95 Mustang -General/Talk- 2
I Electrical help! 03 mustang headlights 1996 - 2004 SN95 Mustang -General/Talk- 2
A 2003 mustang GT- Looking at stage 2 cams SN95 4.6L Mustang Tech 1
S For Sale 2003 Mustang Mach 1 5speed Azure Blue 7,000 miles - fully upgraded and mint. SN95 Mustangs For Sale (1994-04) 0
A 2003 mustang gt - Header leak 1996 - 2004 SN95 Mustang -General/Talk- 1
M Mysterious small green cap and a chugging Stang 1996 - 2004 SN95 Mustang -General/Talk- 4
2003DSGGT 2003 lincoln town car motor block same as the 2003 mustang gt 1996 - 2004 SN95 Mustang -General/Talk- 6
L 2003 Mustang GT 5.4L SOHC engine swap 1996 - 2004 SN95 Mustang -General/Talk- 0
M need help no bright lights 2003 mustang gt 4.6 SN95 4.6L Mustang Tech 2
0 2003 mustang GT cricket like chirp in rear end 1996 - 2004 SN95 Mustang -General/Talk- 1
J 2003 EcoStang 1996 - 2004 SN95 Mustang -General/Talk- 1
M 2003 Engine Noise GT Mustang 1996 - 2004 SN95 Mustang -General/Talk- 8
true01blueGT 2003 mustang gt only left driver tweeter 1996 - 2004 SN95 Mustang -General/Talk- 1
B Looking For Info On A 2003 Mustang Gt The Welcome Wagon 1
